Toro Rosso STR10 Renault
Re: Toro Rosso STR10
i've read somewhere Renault might have done a complete engine overhaul, could this be indeed a sign that they actually have? I remember last year all renault-powered cars were very conservative with the pods/engine covers, only redbull had a 'tight' package, and all teams suffered huge cooling problems.
The tightness of the STR10 package suggests that cooling has been resolved?
interesting to see ALL cars, have MUCH bigger air scoops/inlets at the airbox.
NoDivergence
NoDivergence
50
Biggest intake i've seen in years if not decades
awizul
Gorgeous!!! =D>
Juzh
161
Blanchimont wrote:Let's hope the bigger air inlets hint at more cooling because of more power from the engine and MGUH. What about a very simple calculation: power increase = ~area_inlet_2015/area_inlet_2014 ? :wink:
Anything else would indicate a much worse PU. Can't see that happening.
Don't you rememeber the STR9? :mrgreen:
One of the reasons these sidepods are so tight: the engine oil coolers are not placed in the sidepods, but higher around the engine (near the Bull's head) and fed by the lower rollhoop intake.
http://f1.f-e-n.net/images/f1/2015/2015 ... %20RGB.jpg
douglas
douglas
Blackout wrote:Don't you rememeber the STR9? :mrgreen:
Yes for me the inlet isn't much bigger than on the str9
Kalsi
Kalsi
31
Tightest coke bottle i have ever seen... that unbeliavable air scope and those small sidepods are making me think of a huge internal components reorganization...
If they did a good job with weight balancing and renault really fixed their PU im going to bet this car will be the 2015 revelation
Blanchimont
Blanchimont
214
You may be right with the size of the inlets, will have to do some measurements on this!
Nice profile of the nose from http://www1.skysports.com/f1/news/12433/9691620?
Dear FIA, if you read this, please pm me for a redesign of the Technical Regulations to avoid finger nose shapes for 2016! :-)
desl
desl
36
roadie
39
Funky monkey seat :)
What an incredibly fat airbox, hopefully the Renault is using it well.
f1motta
f1motta
64
Here you can compare Toro Rosso STR9 and STR10 (front view) using interactive slider - http://www.f1talks.pl/toro-rosso-str9-vs-str10
aleks_ader
90
Interesting... But you know there are simply to many factors to account that i belive. 8)
Kalsi
Kalsi
31
Interesting to note the detail on the floor to effectively create an air channel under the sidepods exits...
This sounds to me as the central concept of the aero of the whole car
Never seen a cokebottle this tight together with tight and well shaped sidepods aswell... hope their choice to make all the components in the central line of the car will pay in terms of weight distribution.... if that works... this car is going to fly
dmjunqueira
21
Beautiful car indeed...Let's see if it is fast enough.
