RedBull has finally passed all crashtests.
http://www.autosport.com/news/report.php/id/117529
Juzh wrote:Why?Leon wrote:hope to see shorter nose RB11 a-la Mercedes, Lotus or at least Williams.
mith wrote:RedBull has finally passed all crashtests.
Relevant how?Leon wrote:Juzh wrote:Why?Leon wrote:hope to see shorter nose RB11 a-la Mercedes, Lotus or at least Williams.mith wrote:RedBull has finally passed all crashtests.
Aw, don't be a dick. He prefers a shorter nose, no need being so hostile about it.Juzh wrote: Relevant how?
I meant from a performance standpoint. Why would you prefer short nose? Any other reason other than a personal preference?
I'm asking because the way you put it is as though a shorter nose is de facto a better solution. In which case I ask you to present evidence or some sort of theory at least.
It was a genuine question.fawe4 wrote:Aw, don't be a dick. He prefers a shorter nose, no need being so hostile about it.Juzh wrote: Relevant how?
There's no dickishness here. This is a technical forum, and someone asked for a technical explanation of a view point. That's exactly the behaviour that should be encouraged.fawe4 wrote:Aw, don't be a dick. He prefers a shorter nose, no need being so hostile about it.Juzh wrote: Relevant how?
I wouldn't be so sure of that - a shorter nose needs to be stronger in order to pass the crash test. It probably involves more internal structure. I wouldn't want to bet on whether that, offsets the weight saving in being lower volume or not.NoDivergence wrote:Without taking any aero into account, shorter nose probably is lighter?
not necessarily. who knows, a shorter nose may even be heavier because it has less length available for decelerating the car upon an impact.NoDivergence wrote:Without taking any aero into account, shorter nose probably is lighter?
Considering the fact that, RBR almost stopped developing the car after Singapore GP, they better have done considerable changes to their car to offset power difference in PU, as nothing suggests that Renault would have equaled Merc on PU performance. Although PU was a major reason making them lag behind, but lack of development last season, should only point to major overhaul in their overall new car design. If not, then essentially they stood still 6 months back on car development, only waiting for PU development. That would be quite disappointing. They should know that, in second half of last year, it was Williams that was second best car.PlatinumZealot wrote:Same nose as last year basically....
I'll draw some sketches to explain my point of viewJuzh wrote: Relevant how?
