FW37 Technical Specifications
Chassis construction Monocoque construction laminated from carbon epoxy and honeycomb surpassing FIA impact and strength requirements
Front suspension Double wishbone, push-rod activated springs and anti-roll bar
Rear suspension Double wishbone, pull-rod activated springs and anti-roll bar
Transmission Williams eight speed seamless sequential semi-automatic shift plus reverse gear, gear selection electro-hydraulically actuated Clutch Carbon multi-plate
Dampers Williams
Wheels Aptech forged magnesium
Tyres Pirelli, Fronts: 245/660-13, Rears: 325/660-13
Brake system AP 6 piston front and 4 piston rear calipers with carbon discs and pads
Steering Williams power assisted rack and pinion
Fuel system ATL Kevlar-reinforced rubber bladder
Electronic systems FIA SECU standard electronic control unit
Cooling system Aluminium oil, water and gearbox radiators
Cockpit Six point driver safety harness with 75mm shoulder straps & HANS system, removable anatomically formed carbon fibre seat
Power Unit Mercedes-Benz PU106B Hybrid , Internal Combustion Engine :
Capacity 1.6 litres, Cylinders Six, Bank angle 90, No of valves 24,
Max rpm ICE 15,000 rpm, Max fuel flow rate 100 kg/hour (above 10,500 rpm)
Fuel injection High-pressure direct injection (max 500 bar, one injector/cylinder), Pressure charging Single-stage compressor and exhaust turbine on a common shaft, Max rpm exhaust turbine 125,000 rpm
ERS Mercedes AMG HPP
Dimensions & weight Weight: FIA Minimum, Overall length: 5000mm Overall height: 950mm, Overall width: 1800mm
