Interesting to see the left hand radiator appears to be partially blanked off - there is a black panel in there. Unless they don't need to have the whole area as radiator and this is packaging of some other component. We'll need to see the bodywork off to get a better idea.
I see they have the under-chassis turning vanes and the bat wing from last year. I think these are hugely effective devices. The turning vanes will create a low pressure zone below the chassis which will both create downforce but alsopull air off the front wing. I'd bet this makes the neutral centre wing section work as a wing and create downforce even though the original intention was that it shouldn't do so. The bat wing is obviously designed to create a powerful vortex off which is directed down on to the t-tray, presumably channelled by the t-tray and barge boards to the underside of the leading edge of the sidepod floor. If so, that will be another powerful downforce producer.
These sort of items are rarely discussed because they're quite often tucked away out of sight but I think they're the clever bits in the design. The wings are obvious and talked about a lot. These bits less so.
