more sparks..
Aaronque wrote:https://pbs.twimg.com/media/B9BC3D2IMAA1hCO.jpg:large
more sparks..
Seems like you were 100% right there sector. DRS sheds so much DF it makes the front of the car literally dive into the ground as the speed increases.SectorOne wrote:I guess you change the AoA of the floor due to the loss of downforce at the rear lifting the rear structure up while the front end keeps producing more and more downforce pushing the edge of the floor into the ground.
So i guess whether it´s DRS or no DRS the front of the floor will eventually start hitting the ground given you run it low enough.
*Will Tyson, thewptformula, has. He's a member around here, a young and very good tech journalist. Just to accentuate that since he deserves the credit.
If I remember rightly he's done some excellent lap time analysis in the past and has put other so called professional experts to shame.turbof1 wrote:*Will Tyson, thewptformula, has. He's a member around here, a young and very good tech journalist. Just to accentuate that since he deserves the credit.
Thanks for the kind words. Was cruising this thread for RB11 pictures for my in depth analysis for my blog this weekend.bonjon1979 wrote:If I remember rightly he's done some excellent lap time analysis in the past and has put other so called professional experts to shame.turbof1 wrote:*Will Tyson, thewptformula, has. He's a member around here, a young and very good tech journalist. Just to accentuate that since he deserves the credit.
If this is true, then the RB11 packaging is really crazy, considerung the extremely tiny air inlets and alot smaller sidepods.theWPTformula wrote:The Renault engine is still producing the same amount of heat as last year so the chances of producing much small radiators are pretty slim.
Scarbs said the same. Renault 2015 PU does have the same cooling requirements as last year's. Which is a lot more than ferrari and merc do.gandharva wrote:If this is true, then the RB11 packaging is really crazy, considerung the extremely tiny air inlets and alot smaller sidepods.theWPTformula wrote:The Renault engine is still producing the same amount of heat as last year so the chances of producing much small radiators are pretty slim.
Wahrscheinlich wird der Ilmor-Input mit Rücksicht auf die Standfestigkeit erst beim GP Spanien Premiere feiern. Eines haben beide Versionen gemeinsam: Turbine und Verdichter sind nicht getrennt. Für eine Kopie der Mercedes-Idee fehlte die Zeit.
I'm not sure I agree with that considering what Toro Rosso has achieved with packaging compared to all the Mercedes powered teams including the works team themselves.Juzh wrote:Scarbs said the same. Renault 2015 PU does have the same cooling requirements as last year's. Which is a lot more than ferrari and merc do.gandharva wrote:If this is true, then the RB11 packaging is really crazy, considerung the extremely tiny air inlets and alot smaller sidepods.theWPTformula wrote:The Renault engine is still producing the same amount of heat as last year so the chances of producing much small radiators are pretty slim.
http://youtu.be/j8yEoSjOlSY?t=1m55s
But then maybe we have to consider the size of there air intake compared to the rest?Blaze1 wrote: I'm not sure I agree with that considering what Toro Rosso has achieved with packaging compared to all the Mercedes powered teams including the works team themselves.
