scarbs wrote:5.3.7 The ES must be installed wholly within the survival cell.
Didn't say it was the battery, Scarbs..
I know the video says it is the energy store... but I doubt it. I am basically out on a limb here.
There are talks of new technology between the V, and I feel this is what Honda is showcasing here.
You can see the waffle pattern casted aluminum, something that needs rigidity and light weight. Waffle casted slabs in the world of construction is what you use when you have large spans of ceiling in a building and you want a low slab weight with good rigity without using large beams. Honda has something in that thing that possibly is a moving part or a heat zone (heat exchanger)??? I don't know but it is very curious.
I will produce a drawing of what I think it looks like when righted.
Edit 2: Come to think of it... the Energy store does need to be very stiff too. It is underneath the survival cell as Sarbs said afterall. So chances are 70% this thing is the Battery and 30% it is some mystery technology between the V of the engine. I like the sound of mystery technology so I am going with the later!
