Williams FW37 Mercedes
LookBackTime
LookBackTime
472
Re: Williams FW37 Mercedes
Tobias Grüner AMuS ‏@tgruener
#F1 Updates final Barcelona test: Williams to run new single pillar mounted rearwing, new floor & new sidepod deflectors.
SiLo
138
Pretty sure they have a lot of cooling bits up there. Maybe Mercedes found that moving it up there saves weight with less piping, and frees up a lot of space in the sidepods where more downforce is generated?
The Merc sidepods are definitely very small, not just horizontally but vertically as well.
Felipe Baby!
dren
227
I'd think if that's the case they would have a larger shape to the fin area moving back towards the exhaust, like Mclaren has. Maybe it's a liquid to air charge cooler and cools the liquid in the radiators in the side pods. You wouldn't need the airflow in that area then, like Mclaren requires.
Honda!
LookBackTime
LookBackTime
472
Williams fastest, Red Bull slowest on F1 2015 top speed chart
http://thisisf1.com/2015/02/25/williams ... eed-chart/
Earnard Beccelstone
Earnard Beccelstone
So, Williams is at the top of the speed traps again.
On the assumption that Mercedes will be dominant for a second year running would it be wise, or even possible, for Williams to optimise the car explicitly for high-speed circuits and go for wins there?
It seems to me that there are quite a few high-speed circuits this year - Monza, Spa, Austria, Canada, Sochi - where Williams might press for a win with a low-drag/high-speed set-up. Austria and Spa last year were lost opportunities, I think.
This might/may come at the expense of performance at higher downforce circuits, but I don't think that they were in with a change for a win at these circuits anyway.
I'd love to see some Williams wins this year.
Juzh
161
Earnard Beccelstone wrote:Spa last year were lost opportunities, I think.
How was spa a missed opportunity? They simply didn't have the pace.
The new Central Mounted Rear Wing:
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
Matt Somerfield ‏@SomersF1
Aero update on the @WilliamsRacing also includes an additional VG, curved airflow conditioners & serrated bargeboard
LookBackTime
LookBackTime
472
roadie
39
Great images guys, keep them coming!
So the new rear wing pillar circles around the exhaust and connects to the top of the gearbox?
LookBackTime
LookBackTime
472
Craig Scarborough ‏@ScarbsF1
In adding the new rear wing support pillar, Williams have also removed the low beam wing that used to support the wing
LookBackTime
LookBackTime
472
