Are RedBull alone in having the outer diffuser dip down? The "ceiling" of the diffuser is lower in the outer portion than it is closer to the centreline of the car. This gives them a more defined S section to the diffuser if viewed in longitudinal section. Presumably this is tied in to their treatment of the tyre squash flow and their large overall rake angle.gandharva wrote:
http://abload.de/img/diffu5oqd.jpg
I don't think it was ever about hiding the details. I think it was a way of getting people to look at the car. One of their "we're RedBull and we're mad!" schemes.poolboy67 wrote: to be honest, this livery hides alot more than that silly zebra stuff did
Springs are in the gearbox bell housing. Shocks are in the gearbox bell housing too. Mucch lower centre of gravity and a clear path on top of the gearbox.gilgen wrote:thanks. it appears very light and seems to imply that the springs are below the engine??????gandharva wrote:Its the pull rod of the rear suspension.
Those appear just to be screws. I imagine the 'swan neck' support is made from aluminium or similar material and has an aerofoil shroud made of carbon fibre fitted around it as this is a much easier way of manufacturing such an intricate shape. I may be wrong thoughgandharva wrote:I'm still curious about that rearwing central support. The way it's installed it could easily be used as an f-duct that is fed by a channel from the central air inlet above the driver helmet. If you look at some of the closer shots, you can always see that the support (in vertical direction) is not fully closed especially in the upper part (red circle). Also they could use the 3 screws (blue circles) in the support as some sort of spreader to widen that gap in the central wing support from track to track to increase or decrease air flow coming out of that gap... I would love to see some better high res shots of this area.
http://abload.de/img/central_supportdhqpr.jpg
I've been wondering much the same. A team down on power could really do with a 'device' providing they can get the switching to work (big if).gandharva wrote:I'm still curious about that rearwing central support. The way it's installed it could easily be used as an f-duct that is fed by a channel from the central air inlet above the driver helmet. If you look at some of the closer shots, you can always see that the support (in vertical direction) is not fully closed especially in the upper part (red circle). Also they could use the 3 screws (blue circles) in the support as some sort of spreader to widen that gap in the central wing support from track to track to increase or decrease air flow coming out of that gap... I would love to see some better high res shots of this area.
Red Bull gave a new rear wing leading edge endplate slots that will maybe help with top speed !!!f1316 wrote:I've been wondering much the same. A team down on power could really do with a 'device' providing they can get the switching to work (big if).gandharva wrote:I'm still curious about that rearwing central support. The way it's installed it could easily be used as an f-duct that is fed by a channel from the central air inlet above the driver helmet. If you look at some of the closer shots, you can always see that the support (in vertical direction) is not fully closed especially in the upper part (red circle). Also they could use the 3 screws (blue circles) in the support as some sort of spreader to widen that gap in the central wing support from track to track to increase or decrease air flow coming out of that gap... I would love to see some better high res shots of this area.
The ones they added certainly won't help with top speed.paddyf1 wrote:Red Bull gave a new rear wing leading edge endplate slots that will maybe help with top speed !!!f1316 wrote:I've been wondering much the same. A team down on power could really do with a 'device' providing they can get the switching to work (big if).gandharva wrote:I'm still curious about that rearwing central support. The way it's installed it could easily be used as an f-duct that is fed by a channel from the central air inlet above the driver helmet. If you look at some of the closer shots, you can always see that the support (in vertical direction) is not fully closed especially in the upper part (red circle). Also they could use the 3 screws (blue circles) in the support as some sort of spreader to widen that gap in the central wing support from track to track to increase or decrease air flow coming out of that gap... I would love to see some better high res shots of this area.
Of course they do. But this is rather old news. Pro tip: reading all posts in this thread helps.fawe4 wrote:The ones they added certainly won't help with top speed.
This may give it the potential to stall the outer sections of the mainplane and top flap, reducing drag and increasing top speed, in much the same way we saw teams use the F-Duct and DRD. - See more at: http://somersf1.blogspot.co.uk/2015/03/ ... QlYha.dpufgandharva wrote:Of course they do. But this is rather old news. Pro tip: reading all posts in this thread helps.fawe4 wrote:The ones they added certainly won't help with top speed.
That article clearly says that changes increased downforce and drag.paddyf1 wrote:This may give it the potential to stall the outer sections of the mainplane and top flap, reducing drag and increasing top speed, in much the same way we saw teams use the F-Duct and DRD. - See more at: http://somersf1.blogspot.co.uk/2015/03/ ... QlYha.dpufgandharva wrote:Of course they do. But this is rather old news. Pro tip: reading all posts in this thread helps.fawe4 wrote:The ones they added certainly won't help with top speed.
I'll take that as a fact because it is common knowledge. It is only later assumed that it creates voritices that help stalling the wing.That, I'll only take as assumption. As it is, I really don't see it being used for stalling the wing.Detail changes in key areas like this have to be carefully considered as although they may bring an increase in downforce you also have to consider the penalty they may add in terms of drag.
