Tim.Wright wrote:Andres125sx wrote:wesley123 wrote:No it wont. It only opens the door for everyone to back up their theories with data they know absolutely nothing about.
All Telemetry will show is if something in the car itself caused the crash, which will answer nothing in the whole discussion because it doesn't answer, nor give any signs towards why Alonso was in the hospital for so long and misses the Australian GP.
Sorry but what?
Telemetry show it all, from any driver input to downforce levels. If you see driver stopped moving the wheel and didn´t hit the brakes you´d know he had some sort of blackout before the crash. If you see downforce sudendly decreased you´d know wind played its role. If you see some weird input to some pedal or the wheel you could argue about an electrical shock.You can even see if he went out of the track to the astroturf before going to the wall
Basically you see it all on telemetry
And Alonso was in hospital for so long because he suffered a concusion, same as Perez in Monaco 11 who missed next GP
Very rarely is anything crystal clear in the telemetry. There is a large amount of manual interpretation required to make head or tail of anything whether you are making an accident investigations or a basic performance analysis.
You can't leave this interpretation up to the internet and the tabloids.
Releasing the telemetry would be opening a massive can of worms...
I didn´t say it should be published, only that everything is on the telemetry
To figure something out from telemetry you need to use the program, publishing some graph clarify nothing, you need to overlay different laps to make a comparison, you need to use different data depending on what you´re analizing, you need to compare compare and compare
Nothing is crystal clear in the telemetry...... if you don´t see driver suddenly turned the wheel with no reason, or if you don´t see a drop in downforce, or if you don´t see battery voltage suddenly dropped, or if you don´t see driver suddenly stopped making any input....
There can be tons of facts wich would be crystal clear just watching the correct data in the telemetry
