A post race celebration?Thunders wrote:Honda just keeps going:
https://pbs.twimg.com/media/B_qe7EmWcAABevw.jpg
@Lucky: Nice article. Pretty much Scarbs Version of how the PU Layout is isn't it?
MGU-H transfers recovered energy in KJ (not kw), and that energy is unlimited. Doubtful anyone actually recovers enough to reach K 160 bhp limit. ~90kw was a number thrown around some time ago.PlatinumZealot wrote:Do you mean to charge the battery and propel the car at the same time? Example MGUH out put 200hp to the K.. 160 to propel the car and 40hp to charge the battery? In theory it is possible. I'm not really sure of the situation where you would have excess boost under maximum acceleration though.. but it should be possible.
This.gruntguru wrote: Highly unlikely anyone has more than 120 kW from the MGUH. I did some calculations earlier in the 1.6 thread - can't remember exactly but it was well under 120 kW. The only way would be much higher boost and higher compressor and turbine efficiencies. (I assumed 80%)
Ron Dennis did say that the engine is a "piece of jewelry". Beautiful to look. Not much good for anything else.ringo wrote:The honda seems to be a failure after the first praxtice sessions of the year. I am really confused as to what is so critical that this engine cannot perform at its intended power level. What is really so wrong with it?
And how can such a bad engine pass through so many checks and end up on the track?
Too early to judge the Honda Power Unit a failure. It seems Honda have been very aggressive in the design and the packaging from McLaren means they have a lot of issues to sort through. Once they get on top of the issues then we may see the true potential of the power unit. Could take all season to find out though.ringo wrote:The honda seems to be a failure after the first praxtice sessions of the year. I am really confused as to what is so critical that this engine cannot perform at its intended power level. What is really so wrong with it?
KingHamilton01 wrote:Finally someone with some logic and sense, I like this post and I think later in the season McLaren will surprise a lot of people!Jolle wrote:Looks like Mclaren took big risks to build a winning car from the start, with narrow margins and all tightly packed. I guess it's in their DNA, to design a car that could win races instead of building a test platform (with extra cooling, good and fast acces to electronics, etc).
I don't think Honda made any big mistakes with the ICE, thats pretty straight forward design for a racing company (because of the low revs), so the biggest problem would be in the electronics, wire loom and software. Most of those can be changed without tokens.
So, McLaren has the aero to win, the ICE to win, just have to fix the electronics.... so who knows, they might still surprise us!
but looking in hindsight, with the amount of money wasted in these first few races (not just the whole pm4-30 design, but also two WC drivers), for the same money they could have bought Manor or Catheram last year and raced/tested the Honda engine before it went to McLaren.
source?PlatinumZealot wrote:The Engine is running on 50% of the power range (not sure if this means 50% boost or not) according to Arai.
They are saying that the engine is working 100% reliable mechanically and that the root of the problems is the PU mappings which are up to now, are not dialed in.
