Actually the 1ms panel response time quoted on the box is such a small proportion of the total latency that it is worth ignoring. TVs in particular can do a lot of other image processing (scaling,color correction, god knows what) that affects the latency.MadMatt wrote:Yes its off and I did the trick with Nvidia to reduce lag but the pc monitor you see behind is a 24" ASUS running at 144Hz with 1ms response time so its hard to beat
Ignore the quoted panel latency and measure the total end-to-end latency yourself.
