2015 stats:
- lacks ~100 bhp to mercedes (rumors)
- bad driveability (looks like this has improved in the first 3 races)
- bad reliability
Some pics of 2015 engine:
Ferrari doesn't have Merc innovated split turbo concept. They have Compressor and turbo on one side of the engine and MGU H inside Vtoraabe wrote: Ferrari gained at least 80 hp during winter by adapting the merc innovated split turbo concept, .
Ferrari does not have the split turbo like Mercedes. Ferrari changed from [turbine-MGUH-compressor] to [turbine-compressor-MGU-H] like last years Renault PU. The split turbo of Mercedes PU is not a silver bullet. Even if Renault changes it to split turbo it won't give them 80HP.toraabe wrote:Ferrari gained at least 80 hp during winter by adapting the merc innovated split turbo concept, and to be honest Renault cannot wait to adopt this. Longer pipes from the compressor means pressure drop and because of the higher temp in the conventional turbo even more is lost . With their current design no more power is available only behalf on durability. I also assume due to their concept the engine is running too hot and is suffering from continuous overloading.
http://www.motorsport.com/f1/news/renau ... &q=renaultPerformance was likewise an improvement in Malaysia, although we did keep some in reserve to safeguard reliability.
Now we are getting more confident in this area we can afford to be more aggressive and we should see better results on the straights, with a higher top speed.
http://www.autosport.com/news/report.php/id/118479We knew we had this reliability risk above our heads," he told reporters in China.
Obviously it struck today, not the best day.
We knew it was a weakness so there was a plan in place. We need to make sure the plan is good enough for the size of the issues we had today, and whether it can be addressed fairly quickly.
OK that was new to me.. well.. But if you look at the pipe from the compressor to the intercooler it seems not to be isolated.Silent Storm wrote:Ferrari does not have the split turbo like Mercedes. Ferrari changed from [turbine-MGUH-compressor] to [turbine-compressor-MGU-H] like last years Renault PU. The split turbo of Mercedes PU is not a silver bullet. Even if Renault changes it to split turbo it won't give them 80HP.toraabe wrote:Ferrari gained at least 80 hp during winter by adapting the merc innovated split turbo concept, and to be honest Renault cannot wait to adopt this. Longer pipes from the compressor means pressure drop and because of the higher temp in the conventional turbo even more is lost . With their current design no more power is available only behalf on durability. I also assume due to their concept the engine is running too hot and is suffering from continuous overloading.
Red bull were made to look very ordinary by Torro Rosso, cant support that RB11 is equal chassis with Merc and Ferrari.toraabe wrote:Well according to http://f1-insider.com/red-bull-renault- ... h-technik/
Renault lacks 80 hp to Merc / Ferrari engines in race trim.
In quali trim another 30 hp down due to a „Free-Load-System“ that both Merc and Ferrari are using.
To be honest, this is more than depressive to Renault.
If you look at Riccardo to manage 7. grid with 110 hp down still proves that the RB11 is on level with Merc and Ferrari when it comes to chassi.
It also think this is their actual problem. German media had reports that the engine shows 40 bhp more power on dyno then in car. And they claim it is a big software issue. This imho makes sense, because otherwise they would have gained nearly nothing over the winter from all the hardware upgrades.PlatinumZealot wrote:They have more power but not enough control over it.
hurril wrote:What is a „Free-Load-System“?
