Red Bull RB11 Renault
raymondu999
Re: Red Bull RB11 Renault
Advino116 wrote:They are moving from an upwash design to an outwash design. I wouldn't be surprised if the cascades change to a Merc style soon. To me the change makes a lot of sense. An upwash design is fine back then when the front wings were the full width of the tyres, but since reduction in width last year, the flow off the end of the wing should see much higher blockage from the front tyres, which makes an outwash design a more logical design choice for me.
If you watched Scarbs latest video where he talks about Merc's newest front wing, he mentions the long lead times to design and make one, making me think this change wasn't a recent decision. It might be they revaluated their front wing philosophy after PP left and realised maybe Vettel's struggles with the car is partially contributed by the rear end ingesting dirty air off the front wheel wake which is insufficiently controlled by an upwash design. Else, I don't see a reason why they would totally switch philosophies if the upwash design is sufficient.
If it was indeed a PP thing - surely the McL design would reflect as much?
失败者找理由,成功者找方法
Matt Somers
Matt Somers
179
Advino116
Advino116
19
It does.If you look back last year. McLaren trailed a new front wing in Abu Dhabi (I think) that is almost an exact copy of the Red Bull front wing in terms of end plate philosophy shortly after PP officially joined them. They are using that same philosophy this year, whereas Red Bull has moved away from it.
I am not an aerodynamicist though, so this is just my theory on how the front wing philosophies work and why Red Bull changed it. Take it with a inch of salt.
Back in Abu Dhabi it was nearly an exact copy. Nowadays it has been developed somewhat further. However, it's clear that Mclaren continued with the PP philosophy, while Red Bull moved away from it.
It doesn't mean one is better then the other though.
It took me 2 hours to adapt existing sketches to have illustration of the new wing, but here goes:
Old wing:
Full wing:
Thunders wrote:
FrukostScones wrote: Is this healthy?
I noticed that too, made me cringe. No wonder they're having Brake Problems. :D
Saw it too.. Fortunately the brakes are very light and the hoses are equally as strong.
Godius
186
dren
227
It's evolving closer to what Mercedes used to have.
Honda!
The right inset is actually the 2014 pre-Sepang wing (yes, the actual wing used during the 2014 Sepang weekend was another different one)
http://www.f1technical.net/forum/viewto ... 94#p499294
GoranF1
GoranF1
155
the rear wing endplate,the front wing endplate,and the shape of nose(not tip) have something in common. Any guess? :D
Moose
Moose
52
ajnšpric_pumpa wrote:the rear wing endplate,the front wing endplate,and the shape of nose(not tip) have something in common. Any guess? :D
If this involves elipses....
aral
aral
26
yes. they are all made of carbon fibre! what is my prize?
GoranF1
GoranF1
155
wrong
GoranF1
GoranF1
155
2014 Mercedes RW endplate
2014 Mercedes front wing endplate
2014 Ferrari downwash nose cone design
it makes me wonder did Adrian Newey took too much credit for Peter Prodrumou's aero work over the past years when "originality" was te name of the game at Redbull!?
