Mclaren MP4-30 Honda
rccrdc
rccrdc
Re: Mclaren MP4-30 Honda
ferkan wrote:Not sure if I read it right but Omnicorse suggest compressor is in the V, not in front. That would go along the lines of Giorgio Piola's updated drawing last month. Definitely looks interesting and unique, Button said its "closer" to the Merc solution then the Ferrari/Renault.
Yep! Omnicorse says the compressor is clearly placed in the V of the ICE. Also, not having much space there Honda designed a revolutionary axial compressor (not centrifugal!). Then the MGU-K is between the compressor and the turbine.
240
That's a very unnecessary design solution though, if it is in fact between the V. In front of the engine is just a better solution with no compromise.
ncassi22
ncassi22
31
ringo wrote:That's a very unnecessary design solution though, if it is in fact between the V. In front of the engine is just a better solution with no compromise.
SPACE. No need to make a hole in the tub etc... Not saying it is that way, just that to say there's no benefit might be short sighted.
deschrijver
deschrijver
hurril wrote:
Excellent! (As always.)
The plenum has a very interesting shape.
There's an plate heatshield on it.
In Friday Free practise Alonzo and Button were running different rear wing configurations. Can't find any FP3 shots of both to compare.
JoeE
JoeE
Good luck finding Button pics for he's hardly had any running in any session including Qualifying.
I wonder if there running different engine configurations.
CjC
CjC
On Friday, button was running the wavey rear wing flap, Alonso wasn't.
Today they are both running the 'flat' rear wing flap
Just a fan's point of view*
f1rules
f1rules
635
They taped off the 2 small Slots unterneath the RW Main Plane in the RW Endplates.
Hadn't noticed this the first time I looked at this picture .....You can see the heat at the diffuser.
Mesteño
Don't you think sound has definitely changed?
PS: Well, not that much comparing with this video.
And here you have the pole lap to compare
McMrocks
McMrocks
32
diffuser wrote:Hadn't noticed this the first time I looked at this picture .....You can see the heat at the diffuser.
https://pbs.twimg.com/media/CCzpK8LW4AMWQc4.png
I think it is a reflection. Same for the RW
flat out
flat out
There souldn't be any heat reflections on thermal images. I guess the heat on the top side of the diffusor and the fins of the rear wing comes from the aperture of the bodywork around the rear suspension
3jawchuck
3jawchuck
37
In the live footage you could see the raised dark dots along the edge of the circuit reflecting on the airbox cover.
Jef Patat
Jef Patat
66
flat out wrote:There souldn't be any heat reflections on thermal images.
Why shouldn't there be? Every wave reflects. Thermal imaging is just a conversion of invisible infrared light (remember light's dual caracter being a wave) to visible light (white, red, yellow, blue, black). Visible light reflects and so does invisible light.
And for those not willing to check imightbewrong's addition of last page check this:
http://www.flirmedia.com/MMC/THG/Brochu ... 264_EN.pdf page 27
There's no reason for a heat buildup at the rear wing or it's support to the same extend of the exhaust or tires.
