This was posted by the user muramasa over at autosport.
http://as-web.jp/photonews/info.php?c_id=1&no=76347
Also:
#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
I think a change to the inlet plenum comes at the cost of a token? I don't know, but I doubt a material change would be free.Lucky wrote:https://pbs.twimg.com/media/CEZ68wWWMAEu4Le.jpg
Is that some kind of fibre coating on top of the plenum, instead of plenum itself being made up of fibre element? A metallic object provides far more air tightened sealing than a fibre one, where there is some amount of elasticity in its nature.Lucky wrote:https://pbs.twimg.com/media/CEZ68wWWMAEu4Le.jpg
Some manufacturers have started using carbon fibre intake manifold and airbox to save weight in road cars. Plastic intake manifold is used in road cars to save weight and reduce cost.GPR-A wrote:Is that some kind of fibre coating on top of the plenum, instead of plenum itself being made up of fibre element? A metallic object provides far more air tightened sealing than a fibre one, where there is some amount of elasticity in its nature.Lucky wrote:https://pbs.twimg.com/media/CEZ68wWWMAEu4Le.jpg
You are right, as far as the road cars are concerned. But in these F1 cars, heat inside would play a big part in influencing the elasticity of the fibre.Silent Storm wrote:Some manufacturers have started using carbon fibre intake manifold and airbox to save weight in road cars. Plastic intake manifold is used in road cars to save weight and reduce cost.GPR-A wrote:Is that some kind of fibre coating on top of the plenum, instead of plenum itself being made up of fibre element? A metallic object provides far more air tightened sealing than a fibre one, where there is some amount of elasticity in its nature.Lucky wrote:https://pbs.twimg.com/media/CEZ68wWWMAEu4Le.jpg
Same reason can be applied here.
I see no reason why carbon fibre cannot provide a air tight seal than a aluminium one.
Depends on how the carbon fibre has been structured in the manufacturing process. For all we know there could be a thin layer of aluminium or other material to act as an air seal (no idea if that would be allowed in terms of the regulations). Also heat dissipation in this case might be a help more than a hindrance given where this part is located in the car.GPR-A wrote:Silent Storm wrote:GPR-A wrote: I see no reason why carbon fibre cannot provide a air tight seal than a aluminium one.
