Manoah2u wrote:wesley123 wrote:Manoah2u wrote:
after a collision causing the mechanism to be stuck and immovable. do we really want that?
The same applies to the headrest.
with an answer like that, really, can't take you serious. for real.
Why not? You are stuck with the headrest as well. so therefore, the same applies.
wesley123 wrote:upside down - can't get out. unconsious driver upside down, yeah, that'll be a nice job for the marshalls and doctor to reach the driver when he's upside down with a closed canopy.
The same applies without the canopy.
no, a car upside down is still directly accesible by a marshall that can easily find the seat belt switches to remove an unconscious driver from a vehicle.
Hardly. Plus, they don't really access drivers that way. Apparently bending such a weird curve puts a strain on their back, which apparently is a bad thing after a crash(who knew?)
wesley123 wrote:
Have you seen how many times the F1 helmet visor layers needs to be teared off?
At LM they got these tear offs for the windscreens, so the same applies.
at LM they have windscreen wipers.
Indeed, which is exactly why canopies in F1 would need one as well
wesley123 wrote:
What's next, windshield wipers?
Yes, that does sound like a good idea if you want to apply a canopy.
you're really sinking into being completely rediculous now.
How so? So you think it is a good idea to leave a windscreen covered with rain and dirt and whatnot? Windscreen wipers are there for a reason, and for that same reason, F1 would need one.
wesley123 wrote:
Instead of spending all this money and time on research and work in some 'canopy' idea, this time would be much better invested spending into making sure the REAL cause of the accident is taken away;
So, taking away the cause if these accidents, I assume you are talking about robots?
are you high? or did you just get out with your 'get rediculous and provoke the response i want-leg'?
wesley123 wrote:
the fact that the Japan 2014 race should and must have had been either cancelled or at the very least ended at least 10 laps before the (reasonably fatal) accident of Bianchi occured.
No, but that's a matter of opinion. Afaik Fuji 2007 was way, way wetter(for example). Bianchi went off track because he drove too quick in the corner. To stop a race because a driver can make an error is a bit over-the-top if you ask me.
you know nothing. seriously. and you can't read too, it seems. silly me, thinking you were trying to be serious for half a second.[/quote]
It would be nice if you could discuss in a normal point instead of talking down anyone that disagrees with you.
wesley123 wrote:
it's like demanding motorcycles to have 4 wheels and a cage around them because there are huge holes in the asphalt. the problem is not the motorcycle, the problem are the holes in the asphalt. fix the asphalt.
Except motorcycles are by definition 2-wheeled. But to use your analogy, the asphalt in your analogy is the canopy. the problem that is called is that a drivers head is deemed to be "too exposed", thus, the solution is to remove that exposure by ie. a canopy. You said it yourself; you fix the problem, not run around it.
are you deliberately being delusional?
I'm sorry, but why would i be delusional? I applied exactly what you said. You said;
"it's like demanding motorcycles to have 4 wheels and a cage around them because there are huge holes in the asphalt. the problem is not the motorcycle, the problem are the holes in the asphalt. fix the asphalt."
I'll translate it to you. What you said was; "Instead of applying bandaids to unique problems you fix the cause."
That is exactly what the problem is here; The problem in every situation you named was that the head was exposed, so instead of strengthening a visor, you prevent the head from being exposed.
That is exactly what you said.
wesley123 wrote:
So earlier you said that people should fix the problem, instead of turning around it giving an alternate solution to the individual problem, yet, here it suddenly is okay? In every case here the problem was the head was too exposed, thus, the solution would be to stop that exposure. That's exactly what you pointed out with your analogy.
no it wasn't. you twist words and turn it into your own bent theory for some reason. something you like to do repetitevely. and trying to scoop around everything written around it. go ahead and live in your own bubble.
Ah well, at least I actually go in on the content, instead of turning around it making accusations(oh, see what I did there?). You know, instead of just making accusations here and there because i don't agree with you, how about you actually point out flaws? It'll make the discussion a whole lot nicer for everyone.
wesley123 wrote:
remind me again why on earths'name this stupid canopy idea still has life in it while it's a 50 year old dead horse that keeps getting poked again and again?
Because the drivers head is exposed, and recent events have pointed out that that still is a problem.
you just read that for 50 years it has been proven it is not a problem.
Really, because all those collisions with debris and heads and near-misses shows otherwise.
Now please, instead of calling me whatever for disagreeing with you, how about you actually discuss what is being said?
Like a famous saying goes; Attack the post, not the poster.
