Williams FW37 Mercedes
Re: Williams FW37 Mercedes
LookBackTime wrote:Got these comments about Williams Fw37 Austria updates from an user (MikeF1 - many thanks!) of other F1 site:
Don't know how much of the update has been pointed out here but the obvious ones.
Wing (rear)
bargeboards
diffurser edges with rear brake winglet changes and brake cooling adjustments.
Less obvious ones (told from a friend at williams.
The leading edge of the floor on the underside and top of had some minor changes, but the main change is the profile of the underside of the car (nose to drivers bum) focused on feeding more air around the sides of the car. The only visible part of this upgrade is the turning vanes that dangle from the chassis. They have gone through some fairly evident refinements (where the 2nd winglet meets the chassis, a gap has been put in to help push the air outward) also general shaping of this component
It was quite an interesting conversation. He said that the vehicle may have inherent weaknesses that could not be rectified this season. It is a trend that has carried over in the last 3 years to varying degrees and is the last bad egg in the Williams car gene. It is also proving to be the most difficult as the vehicles strengths sugar coat it. The downforce added on will go a long way to making the tyres more compliant, and that is half the battle. generating usable downforce at all times through the wheels. the other side of the coin is to generate mechanical grip to keep the tyres good and pointing in the right direction when downforce starts to eb away, and the transition from downforce to mechanical grip is poor. The problem is, if they can't find a solution for it this year, then teams will jump us next year like ferrari.
Not the first time I am hearing about this notorious weakness in the William's car architecture. Every year they say the found the solution and then come the following year they still have it.
Spoutnik
Spoutnik
Williams need to focus on their strenght, they not reach the best car, they don't actually want to win the Championship, they want to score big points this year. Actually they make great work, without big amount of money. But tbh I think, they need some upgrade to fight with Ferrari at the regular. The last year car also know a difficul start of year because Williams lack on track like Monaco, and they need some conditions for a good exploitation of the car, but during the second half of the season, Williams will raise a bit, firstly at Silverstone with good chassis and fast car, and especially with high speed/fast corner track like Monza, Spa, Interlagos, Austin, Abu Dhabi .. But they will struggling with their lack of downforce at Budapest, Singapore obviously. I can't see Red Bull with all penalty they earn, reached thie 3rd place at the Constructor Championship.
roadie
39
Can the team make a rear wing work without a monkey seat or is it more efficient to produce downforce and drag there than elsewhere?
LookBackTime
LookBackTime
472
Very intriguing picture (see the winglet in front of rear tire)
And here we have a ban for brake duct winglets in the making :P
GM7
Wow so strange ?!?
Francesc
Francesc
49
LookBackTime wrote:Very intriguing picture (see the winglet in front of rear tire)
Actually there are two winglets there. One next to the floor edge and the other most visible one. :wtf:
LookBackTime
LookBackTime
472
What is "the thing" below the floor (close the rear tire)?
Possible answer:
Craig Scarborough ‏@ScarbsF1
@tgruener odd there's fence with a sensor under the floor too
LookBackTime
LookBackTime
472
dren
226
I thought winglets were not allowed in that area? Also, does the edge of the floor curve down?
Honda!
The FIA might not like this.
Please ban that Yesterday. [-o<
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
Craig Scarborough ‏@ScarbsF1 7m7 minutes ago
@tgruener ouch! Just read the regs and there is loophole there! How come no one's noticed this?
