[IMG:600:400]http://img210.imageshack.us/img210/810/untitled2lm9.png[/img]
If the black thing is the wheel, the light grey the dumper, the darker grey thing holds the wheel and moves with it up/down around the dumper when expirencing bumps, and the blue thing is hydraulic device that alters the angle of the dumper and by doing do it alters the camber of the wheel.
If you put a sensor in each corner of the car, which measures the distance of the car to the ground and tells the hydraulics to alter the camber you´ll have perfect camber controll
Would this thing actually work?
