Mclaren MP4-30 Honda
McMrocks
McMrocks
32
Re: Mclaren MP4-30 Honda
maguetox wrote:
CjC wrote:Low power running?
If they were running with the power down during this test, McLaren is closer to the front than everybody think, because with the actual differences, even if they are representative, when they can run at full power, if someday they can do it, the differences will be almost cero. The big question is when they are going to run at full power with a good reliability.
At least for this test: =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D>
Renault can't run their engines at full power even in their second year. Same could apply to Honda
palimpodio
palimpodio
Another pic from AMuS...
rccrdc
rccrdc
That is very interesting. They used red Flowviz at the Front and Yellow further Back. You can see where they mix up on some Pictures.
Looks to me like they also have a "Batwing" like Mercedes - Or is it something else ?
bonjon1979
bonjon1979
30
mclaren111 wrote:Looks to me like they also have a "Batwing" like Mercedes - Or is it something else ?
http://1.bp.blogspot.com/-eFvJLjjv-2M/V ... 862370.jpg
That is a Mercedes. Note the silver colour and the beginning of sponsor name Blackberry.
I know it is Merc :)
The picture is for comparison :!:
McMrocks
McMrocks
32
I don't think McLaren has a bat wing.
What you can see under the tube is some kind of sensor all cars (or at least some) are running. Just an airfoil shaped thing
edit: look at this picture from this article which says
– The laser sensor to record the car’s ride height is a must on all modern F1 cars
Jef Patat wrote:I'd never have thought the airflow goes down like that at the beginning of the sidepod, I would have thought it to be more horizontal. Or is this because of the Y250? Anyone can shed a light on this?
What's a Y250, Potato ?
All the Pictures in higher Redolution for the ones that know how to interpret it. :D (Open in new Tab for full Res)
Found them on the autorsport Forum.
Edit: Matt Somerfield's take on the Austria Updates: http://www.grandprixtimes.com/news/display/10424
Thank you Thunders for these nice high resolution pictures =D> =D> =D> =D> =D>
Silverstone should be another performance step forward, with Honda set to introduce performance updates and McLaren scheduling the debut of a new lighter monocoque.
Anybody know what sort of Kg's reduction for the new chassis ?
CjC
CjC
0.1?
:P
Just a fan's point of view
I've been told - secondhand - that's it's just shy of 2kg - so it's not a great deal - mainly from lay-up improvements and changes to the upper engine mountings (So, I assume the CoG is a bit lower for the tub even without an extra 2kg of ballast on the floor, which is probably more important)
Jef Patat
Jef Patat
2kg? peolple have been claiming the car lost more than that because of the new paint job :lol:
