ringo wrote:I have inputted the high a:f into my calculator, and ive realized that Honda's engine cannot be used as a prime example. There is a great power loss when compared to stoichometry. The flame temperature in the cylinder just too low. I notice high boost is used momentarily, it may be some fuel saving tactic, but high a:f doesn't really have any theoretical advantage, it must be some real life occurrence in the cylinders that may have been referred to in the engine thread.
Honda's engine is underpowered, and maybe they are just doing things a bit differently with their unit. It would be good to see data from a mercedes or ferrari engine.
The reason I think its so is because as you approach the upper rpm fuel limit you can load the turbo with the MGUH and lean the A/F ratio and pull more energy from the turbo. If you run it full rich you will be hitting the fuel limit at a lower boost with less energy. The difference from my calculations are about 20HP.
In my above quote my reference to
lean out the A/F ratio, I didn't state what the A/F ratio is? In my calculations and sims I'm talking no more then stoich up to 16:1 A/F ratio being max. Any leaner as you stated you start losing exhaust temperature.
So I think they are running full power rich and as they approach the higher rpm before they up shift is when they could get the most output from the turbine by running stoich or a little leaner then stoich.
