Tommy Cookers wrote:@ gg
my first impression - isn't this paper founded on the concept that there is no 'free' power recoverable from raised exhaust pressure ? the opposite of your position, that (turbine power-compressor power) yields 'free' power that's too good to be ignored ??? fwiw - I expected raised exhaust pressure, as raised electrical power is in F1 worth even a corresponding fall in crankshaft power
Sure - no improvement in Brayton recovery with increased PR (increasing MAP and EBP by the same amount to maintain crankshaft MEP) under the assumptions used:
- 80% compressor and turbine efficiency. (Better efficiencies would however favour increasing PR).
- Intercooling to ambient. Any intercooling is energy lost to the Brayton machine. As I mentioned in the Honda thread yesterday, intercooling could be reduced at higher PR and Brayton work recovery would improve with increasing PR.
Of course the main benefit of higher PR is a leaner overall AFR:
- Mixture in spark region needs to be 1.0 - 1.2
- Leaner mix as flame progresses for best combustion and for knock resistance (lower flame temp)
- "Zero Fuel" zone at chamber extremities to avoid quench and unburned HC
- Increased scavenge air for chamber cooling and complete removal of combustion products.
