alexx_88 wrote:Brembo brake facts: Italy (117kWh), Spa (101kWh) and Silverstone (85kWh). Monza is the exact opposite of what you describe, as it's one of the top circuits on the calendar regarding the potential to harvest energy from braking.
No, it is not one of the top circuits on the calendar for brake recovery. In fact it is average, or slightly below, the average harvest at all circuits.
The numbers you quote there are for the whole braking system. More than half that goes through the front brake, and cannot be recovered.
And the MGUK can take only 120kW of the rear braking power available.
So the question is, how much time is spent braking where the rear brakes are generating 120kW or braking or better?
Singapore is the best circuit on the calendar for MGUK recovery - more than twice Monza (better than the 2MJ limit in the rules), and around three times that of Silverstone.
