2015 Tyres - Medium and Soft
Don't forget the power loss due to the air density, this will also play a major role: stoichiometric combustion will need to be adjusted, so the engines which can compensate best for the air loss will have a major advantage. I believe that we can learn more about the engines from this race than most others.hollus wrote:Elevation: 2285m.
With air density being ~76% of its sea level value, cars can go 9% faster before drag consumes the same power as at sea level. And with turbo engines, power will only be very slightly down.
There might be potential for Monza-like top speeds even if the teams choose to run extra wing angles to compensate for the thin air. And if someone runs a Monza-like setup... One can dream!
Come to think of it, cooling capacity will also be down by 24%. We might see some interesting compromises here.
I feel it's more of a Monza, Canada like track. Whatever package worked well in Canada will work well here.WaikeCU wrote:Could imagine STR running a low drag setup perhaps, but this is not like Monza kinda track. Feels more like a mix of Fuji, Silverstone and Istanbul.
It also means less downforce, so they'll probably run higher-then-expected downforce configurations.hollus wrote:Elevation: 2285m.
As we saw in Brazil last year - Air pressure does very little to this generation of engines. They lose a tiny bit of power, but not close to what the V8s (or earlier) did.CBeck113 wrote:Don't forget the power loss due to the air density, this will also play a major rolehollus wrote:Elevation: 2285m.
But does it doepn't change the downforce to drag ratio. Both drag and downforce are linearly related to air density.turbof1 wrote:It also means less downforce, so they'll probably run higher-then-expected downforce configurations.
It's the VO2 max. Athletes have their aerobic respiration finetuned to normal oxygen density, to their V02 max. With less oxygen they will not be able to hold on to their normal V02 max if not adapted properly: they simply have less oxygen in their body to burn.PlatinumZealot wrote:It is 71 laps in thin air. Athletes usually need a full week or two of training to adjust their bodies to the air of Mexico city. Why not F1 drivers?
Thats great!! light rain is enough to have a great race. Because if it rains more we will spent the hole race after the safety car or even worse, with a red flag.f1316 wrote:Really looking forward to this one, seems like an interesting track in a location with a passionate fan base. Stadium section seems visually cool.
Looks to me like, bar Friday, the weather's going to be changeable though. I would like to see how the Ferrari (with supposedly less thirsty PU) would fair here vs the Mercedes in the dry but looks like practice might be the only opportunity for that.
Still, if it rains and we get a race like last week, who's complaining?
