water dyno
johnny comelately
johnny comelately
110
water dyno
does anyone know (not speculate) if air in the line of the hydraulic line from the master cylinder on the water brake and the gauge will give the wrong reading?
01j
01j
Re: water dyno
As a general rule, pressure is the same everywhere in the line. Therefore, the air will compress until it's pressure is the same as the fluid in the line. The only drawback, in theory, is the response time of the gauge, which should be only a second or two delayed.
flynfrog
Re: water dyno
01j wrote:As a general rule, pressure is the same everywhere in the line. Therefore, the air will compress until it's pressure is the same as the fluid in the line. The only drawback, in theory, is the response time of the gauge, which should be only a second or two delayed.
not true at all you still get a head loss
Greg Locock
Greg Locock
237
Re: water dyno
wrong. the gas compresses to the same pressure as the surrounding fluid, and the gauge works on pressure. 01j is right.
