That's... awkward? Or maybe the ICE needs the new turbocharger (the other 4 tokens) to work properly?
turbof1 wrote:
I've readed it a couple of times, don't know where anymore. Of course reputations are not always true, but I haven't heard anything bad in any case from those parts.
The issue with Brazil is a combination of a high altitude and a very twisty track, meaning you'll not recuperate a lot of energy through both braking and the turbo. The long straight however will give the turbo more time to deliver energy to the mgu-h. Since energy from the mgu-h to the mgu-k (and then right on the drivetrain) is unlimited, one can benefit greatly in this area. I think this is one of Renault's strong points. Just a hunch.
If I remember correctly it was said by an enginner (a Mercedes one?) during SPA GP weekend or directly after. In his opinion Renault's MGU-K is the most efficient and able to deploy the energy stored for more time... or something similar.
Edit:
Here it is
gandharva wrote:They say that the best part of the Renault engine ist the MGU-K. So the power from the battery lasts really long compared to competition. A Mercedes engineer told them, that after corner 16 the batteries are done in Spa and the system has to switch to MGU-H. But MGU-H usage comes at a cost. It takes away power from the combustion engine because of exhaust back pressure.
