If all of that is true then simply switching the ice to a "superior" version should have provided a gain, not a loss in performance even without the new turbo.ripper wrote:That's... awkward? Or maybe the ICE needs the new turbocharger (the other 4 tokens) to work properly?
If I remember correctly it was said by an enginner (a Mercedes one?) during SPA GP weekend or directly after. In his opinion Renault's MGU-K is the most efficient and able to deploy the energy stored for more time... or something similar.turbof1 wrote: I've readed it a couple of times, don't know where anymore. Of course reputations are not always true, but I haven't heard anything bad in any case from those parts.
The issue with Brazil is a combination of a high altitude and a very twisty track, meaning you'll not recuperate a lot of energy through both braking and the turbo. The long straight however will give the turbo more time to deliver energy to the mgu-h. Since energy from the mgu-h to the mgu-k (and then right on the drivetrain) is unlimited, one can benefit greatly in this area. I think this is one of Renault's strong points. Just a hunch.
Edit:
Here it is
gandharva wrote:They say that the best part of the Renault engine ist the MGU-K. So the power from the battery lasts really long compared to competition. A Mercedes engineer told them, that after corner 16 the batteries are done in Spa and the system has to switch to MGU-H. But MGU-H usage comes at a cost. It takes away power from the combustion engine because of exhaust back pressure.
The fact they went backwards shows either Renault screwed up ... Again, or the ice mapping Renault provided was excessively conservative. Or both.
