Mercedes AMG F1 W06
Leon
Leon
Re: Mercedes AMG F1 W06
"Clouds now and again
give a soul some respite from
moon-gazing-behold."
Matsuo Basho
Matt Somers
Matt Somers
179
Certainly can't remember seeing this on the Merc before...
wouldn't that just be the steering arm protruding as he makes a left turn out the box?
Matt Somers
Matt Somers
179
Ok, perhaps I should have specified I've not seen it exposed like that before (not saying it hasn't been)
.poz
.poz
50
or as suggested on fpassion they are testing a new third element on the front suspension and hiding it with a fake sduct
http://www.formulapassion.it/2015/11/f1 ... epistaggi/
SiLo
138
How does that work exactly? Like a third spring at the rear connected between each side?
So when both sides are under compression it remains stiff, but if its just one side it will compress.
Felipe Baby!
Jolle
Jolle
133
.poz wrote:or as suggested on fpassion they are testing a new third element on the front suspension and hiding it with a fake sduct
http://www.formulapassion.it/wp-content ... e-2015.jpg
Possible, but I would guess it would be more cleaver then to make the S-duct cover as wide as the chassis to hide all the bumps and springs.
Maybe they had some strange tubing to steer the air trough the chassis.
FrukostScones
162
Omnicorse.it on Merc front suspension tests:
https://translate.google.de/translate?s ... t=&act=url
F1NAC
169
So they just removed that "third element" when they went to saturday? I mean on sunday they didn't run with bulge.
dren
226
I find that hard to believe. It isn't a super secret idea to run a third suspension element.
They either put a bulge there and people suspect they are trying a new suspension upgrade or...
They put an S duct there along with a bulge that looks like they are trying an S duct with a suspension upgrade.
Honda!
.poz
.poz
50
dren wrote: I find that hard to believe. It isn't a super secret idea to run a third suspension element.
Last rumors says that the s-duct panel was to test the driver visibility with an higher chassis and that they were testing an hydraulic interconnection between left and right suspension
dren
226
If it was for driver line of sight I would think it would span the full length of the bulkhead, not just in the center.
Honda!
dans79
267
dren wrote:If it was for driver line of sight I would think it would span the full length of the bulkhead, not just in the center.
It didn't when Brawn did the same!
201 105 104 9 9 7
The blisters on the the Brawn did cover the edges of the drivers vision though, which does matter alot for driver visibility.
I think it is too late to do any testing for a higher chassis. The W07 tub would have already been sign off by now and well into manufacturing.
I think it is only an honest to goodness S-duct.
dren
226
PlatinumZealot wrote:I think it is only an honest to goodness S-duct.
My thoughts as well.
Honda!
