djos wrote:Btw, it just occurred to me that Ricciardo being slower in a straight line using the new PU is even worse when you factor in the fact Kyvatt was running a PU which had already done at least 2 races Iirc.
When an updated engine is marginalised as to what it can do, for whatever reason, it will not perform exactly as intended.
Try putting the same air filter system of a 3.0 litre M3 engine onto the updated 3.2 litre evo model.
They share the same bore with the 3.2 getting a longer stroke.
The requirements are near identical, but when you put the 3.0 litre models airfilter system onto the 3.2 litre model, power output drops to just below that of the 3.0 litre(weather dependant).
For various reasons the part simply was not designed to be used with the updated, but basically same engine.
