hemichromis
hemichromis
Re: Honda Power Unit
So a smaller motor could be used and operated at a speed where it is still reliable?
Is this the standard arrangment in all power units?
Thanks
Pretty much, yes.
damager21
damager21
Honda is searching for ERS engineer and technician. Looks like they are ramping up their team working on this hybrid system. Wondering if its a bit late in the day to scale up their team.
http://www.racestaff...ngineer-116.htm
http://www.racestaff...hnician-115.htm
Joseki
Joseki
damager21 wrote:Honda is searching for ERS engineer and technician. Looks like they are ramping up their team working on this hybrid system. Wondering if its a bit late in the day to scale up their team.
I've seen those links a few months ago, probably in August, so I think they already have some new people on board for the 2016 hybrid system.
http://f1news.autoroad.cz/novinky/74891 ... dsouhlasen
Arai-san said they have decided with McLaren the way to go with the concept for next year.
Chuckjr
livinglikethathuh wrote:If McLaren does not build a killer chassis sculpted with the hands of Athena, this means no podium for McHonda for another year.
Yes, Athena is now known as Prodromou. :wink:
Watching F1 since 1986.
FW17
185
Honda hiring more consultants
Guess the Milton Keynes office has changed from race support to R&D
livinglikethathuh
livinglikethathuh
He better be.
lio007
327
Some quite good pics of the Honda PU: http://en.f1i.com/magazine/29541-exclus ... -unit.html
trinidefender
trinidefender
318
One thing I have noticed between the Honda and the Merc is the way the blocks are built. It looks like the Honda block is a casting or forged. The Mercedes block almost looks to be billet. Even if it isn't billet it surely has a lot of machine work done to the outside that is clearly evident, if it is billet then I have no idea how they would manage to make it that complex on the inside.
trinidefender wrote:One thing I have noticed between the Honda and the Merc is the way the blocks are built. It looks like the Honda block is a casting or forged. The Mercedes block almost looks to be billet. Even if it isn't billet it surely has a lot of machine work done to the outside that is clearly evident, if it is billet then I have no idea how they would manage to make it that complex on the inside.
Every single reciprocating piston engine I've ever seen is cast.
Brian Coat
Brian Coat
Yes, non-cast blocks are well known in motorsports but like you I've not seen it in F1 on the track.
That's a machined-from-solid timing cover in image "MERCEDES (2014)" not the block I believe, which I'd expect to be cast
Pierce89
60
The current Ford WRC block is machined from a single billet.
dren
228
The Honda ES package with controls along with the MGUK look to be the smallest of the three. Haven't seen Ferrari's.
Honda!
Forged engine block? Sure about that one? haha
Vortex37
Vortex37
A very quick bit of manipulation of Lieo's pic, is revealing. Is that a ceramic blade? Or is this a picture from a broken unit? The angle looks very strange. Twin turbine linked to a common shaft?
