hopefully they dont destroy it with an ugly cockpit covering!!!!!
btw the car doesnt seem quite dramatic to my eye
#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
I very much dislike the bigger wings, aesthetically. Although I did got used to it during the 2009-2013 era, it was an inmediate improvement last year. Now we probably face even bigger front wings then 2009-2013... .Thunders wrote:The 2017 Aero regs have been agreed on, with the direction going to make it harder to overtake, as already feared by many People.....
http://www.motorsport.com/f1/news/new-2 ... d-symonds/
Front Wing: I would narrow this down to 1500mm and simplify the end plate - must lie on a single plane, which can be angled in any direction, but obviously that would reduce the usable wing width.ESPImperium wrote:Personally, I've thought there is a chassis evolution that can be made on the present chassis regulations.
Front Wing/Nose: Leave as it is for the wing, but clean up the cascade elements to reduce their impact and limit the 'Gillette Mach Fusion' evolution with the front wing being limited to 5 elements. As for the nose, bring it back to 2014 regulations but tidy the wording up so that the thumb elements/look is gone. As for nose height, again 2014 heights for safety, but those will yield performance.
Rear Wing/Diffuser: Leave the height of the wing the same, but bring them back to 2008 widths to make them more aggressive looking. Also bring back the beam wing with a standard central section either side of the crash structure. Diffuser height will be raised to the 2009 175mm height (i think) but ban gurneys around the upper side of the diffuser. Also start the diffuser earlier on the underside.
Suspension/Tyres: Make the front tyres 300mm wide and the rear tyres 400mm wide, also make the rims 15 inches in diameter. This should be the best mid way to increase mechanical grip and speeds. As for suspension, Id consider allowing the teams to interlink again, but not front to rear, only left to right side for better roll control, however if they wish to do so, they must do it with a no more than 5bar pressure.
Electronics: Standardise electronics for all engines, make sure all teams have the same access to the same toys, how id do this is by limiting the rotaries/buttons on the steering wheel and also limiting the amount of active sensors when a car is on track.
Engine: Leave as the same, however tweak the token system to allow slower power units to catch up, but also allow in season development and a good amount of out of season development as well. The noise I'm happy with as it is bringing more of a family audience to races these days.
Others: BAN tyre blankets, also ban tyre pressure sensors and also tyre wear sensors. Drivers need to call their own tyre strategies on what their 'feel' is telling them. Also all cars must start the race with no lower than the prescribed pressure by the tyre manufacturer, they can start higher if they wish, but no lower than the tyre manufacturers lowest PSI.
I think this would bring back the lower teams into the mix, and also allows a gentle 3-4 second lap time quickening.
You will find yourself in a situation with cars with massive understeer. You can't just make the reads wider and expect there to be enough grip at the front. With a smaller front wing this problem will only get worse at high speeds.wuzak wrote:
Rear Wing/Diffuser: I agree that the height of the rear wing is ok, but the width is too narrow and leaves too much of a gap. For the diffuser I would follow the example of GP2 and Indy and have the diffuser start well in front of the rear wheels in order to gain ground effects.
Wing elements: I suggest that the number of elements allowed on the front and rear wings be restricted to 6. These elements can be placed on the front wing, upper rear wing, beam wing or on a position between the beam and upper wing. Thus you could have a 3 element front wing, single elements for upper, middle and beam rear wings. Or three front, two upper and single beam. Or a triple upper rear wing, a single beam wing and two front wing elements.
I'd also like to have rectangular boxes that enclose this wing elements have a total combined cross sectional area. Possibly similar to what it is today, possibly less.
Suspension/Tyres: Keep the front tyre widths as they are, make the rear tyres much wider.
Overall width to be 2150mm.
The reason they apparently raised the rear wings is to reduce their wake impact on following cars, so lowering them again seems pretty counter productive to go back to them, regardless of how they look.mahinderlasmibal wrote:Hopefully they will bring back the lower positioned aggressive looking rear wings, it is a shame that f1-cars of today are sporting such hideous tall RW's
https://41.media.tumblr.com/e9cfaf3079c ... o1_540.jpg
