Scuderia Ferrari SF16-H
Joseki
Joseki
Re: Scuderia Ferrari SF16-H
ollandos wrote:looks like mclaren or its only my view?
It's mine too, there's a bit of McLaren in there.
Look how the 'air box'starts drooping much earlier than F15T... Maybe a hint that the compressor moved much forward..?
Alonsofor2017
Alonsofor2017
hmm this is quite interesting would be good to see a comparison between the mp4-30 and sf16-h to compare/ see which one is tighter, maybe this is a sign that mclaren are going a good route in terms of aero
Yurasyk
Yurasyk
It seems, we definitely have a longer wheelbase
bonjon1979
bonjon1979
30
Silent Storm wrote:
bonjon1979 wrote:
Silent Storm wrote:I think wheelbase is same as last year.. If anything they might be a tad shorter 10-15mm maybe
How can you tell this?
https://twitter.com/eligp/status/700676220560785408
Both images are not at same scale but if they were I don't think there would be much difference between both cars.
We have this every year. It's impossible to compare accurately compare wheelbase of cars from photos that are taken at different times, from different lens', from different distances. certainly not to the degree you're suggesting.
Joseki
Joseki
I don't think this prove anything, we already knew the MP4-30 was a good car.
dren
227
Slimmed down and stretched sidepods. The cooling must be impressive. I expect the rear might open a bit more during testing. Also, there are cooling exits now on both sides of the driver. The sidepod slope from top to bottom is more like the rest of the cars now. Over the past several years it had a bit of a side slope to it.
The lower front suspension members look like they reverted back to normal rather than the combined Mercedes style, at least from looking from the top.
The air box for the engine only has one support pillar, and it's tiny.
Overall a very sleek, good looking car. They improved in all the right areas aero related. PS, the livery looks good too - ha!
Honda!
Alonsofor2017
Alonsofor2017
https://pbs.twimg.com/media/CblNS4QUAAANp0A.jpg
well we dont for sure unless engine is good, but i think the angle of the mclaren pick is slightly different but by the looks of it ferrari is just as tight at the back and is smaller at the front because of smaller inlets, good news
Radiator layout has clearly changed. Hence the very different sidepods/engine cover...
bonjon1979
bonjon1979
30
Blackout wrote:Radiator layout has clearly changed. Hence the very different sidepods/engine cover...
Looks like those comments about upright radiators was true. Seems to have allowed them to slim down the sidepods much sooner.
Gilles27Kimi7
Gilles27Kimi7
25
Well, it's interesting to see how the Zero-size™ concept has been implemented by Ferrari
Juzh
161
Yurasyk wrote:It seems, we definitely have a longer wheelbase
http://i.imgur.com/s66Wg6t.jpg
This will surely impact low speed agility, will it not?
F1ern
F1ern
16
Front tyre, front and rear wing is much bigger in the SF16-H side.
cmF1
Can someone please explain the benefits of having a bat wing on the role hoop?
プラスとマイナス
cmF1 wrote:Can someone please explain the benefits of having a bat wing on the role hoop?
It straightens airflow toward the rear wing.
