Haas 2016 car Ferrari speculation Thread
F1NAC
170
Re: Haas 2016 car Ferrari speculation Thread
Front wing c/p from SF15T
kreuzass
kreuzass
In fact of the first season nice and high developed car. Wow!
Tomek1623
Wow a lot of sponsors!
Can't wait to see it on track. Interesting that Richard Mille is present both on the Haas and McLaren cars.
stuartpengs
RicME85
52
So that yellow CAD model was the Haas car
If you want to campare, you should compare it whith the older Ferrai cars. It shares some DNA with them (blown front axle with oversized brake ducts, turning vanes design under the nose, splitter design, sidepod intakes, rear wing etc) And FW
GM7
Looks nice. Nose cone is exactly like the one from page 1 :mrgreen: Its a bit fatter then SF16-H in the middle, but none the less its very nice looking car. Livery is horrendous though :cry:
I was right, thank Canal+ ahah :P
RicME85
52
Blackout wrote:If you want to campare, you should compare it whith the older Ferrai cars. It shares some DNA with them (blown front axle with oversized brake ducts, turning vanes design under the nose, splitter design, sidepod intakes, rear wing etc) And FW
Has the SF15-T's sat on and squashed look to the rear of the sidepods
Clown
Clown
Interesting tyre squirts
RicME85 wrote:So that yellow CAD model was the Haas car
THIS!!!
230
I would say we are looking on an unfinished car. Those pieces may be fitted once the car hits the track.
RW is basically the same. Only the base of the vertical support is not shared
andone89
andone89
The rear wing looks 99% copy of Ferrari's rear wing, minus the fancy paintjob.
Sniffit
Hmm, no pitot tube and no antenna..
