Formula One's governing body has announced that it has come to a settlement with Scuderia Ferrari after investigations into its 2019 power unit, considered the most powered in F1.
ME4ME wrote:I think the reason for moving the MGU-K is more likely aerodynamics than weight distribution. They probably want to tighten up the rear "coke bottle" shape even further. Additionally there might be a slight weight saving and efficientcy increase from shortening power cords.
More room for cooling flow too.
But putting the MGU-K on the side of the engine with its shaft going to the rear should have almost identical length of power wiring as the shaft going forward. Also, its not clear why cooling flow would be better.
Aerodynamics may be the reason, but even that seems marginal. The MGU-K itself would be in about the same place either way; only the gearing to the crank (which should be small) is located in a very different position.
You have a greater cross section in the back for flow going through the car if the MGUK is moved ahead.
The engine cover is smaller as you go to the back, so getting the MGUK out of that region should free up space for air flow.
You guys have it wrong. The mguk is moved CLOSER to the gas tank end of the engine but just like mercedes honda and renault it has its own little driveshaft that delivers power to a small set of gears to the mating end of the cranshaft.
Do you suppose any team takes advantage of the full 3.33:1 ratio they can use to gear the MGU-K to the crank? Also is the 200nm of tq the MGU-K is allowed to deliver measured at the crank or just the MGU itself?
Well 200nm is a decent amount. More than most street cars. Lets work it out withought going into any complicated motor theory...
F1 engines idle at around 4k rpm.
Lowest shifting range during a race is about 7k rpm
High shift is about 12k rpm
At 120 kw regulted mguk power delivery best case, the torques at those rpm would be: 286 Nm, 163 Nm and 95 Nm.
These torques are within close range of the regulated 200 Nm. Therefore we can conclude that the torque added by the mguk is checked at the crankshaft of the engine.
This leads me to believe that the teams are free to use whatever gearing they need as long as they don't exceed the 200 Nm (or the mguk rpm limit). Actually, having thought about it some more, it would be advantageous to have the mguk rotate as fast as possible as this reduces the size of the gearing and also reduces the size of magnets (or field coils as the case may be), it reduces torque at the motor and also the inertia of the motor.
Granted, lap times from day 1 of testing probably mean nothing, but I'm still mildly entertained by seeing the Toro Rosso with the 2015 Ferrari engine having posted the second fastest time for a Ferrari powered car... Possibly says more about Sauber and Haas than anything else.
mkable1370 wrote:Granted, lap times from day 1 of testing probably mean nothing, but I'm still mildly entertained by seeing the Toro Rosso with the 2015 Ferrari engine having posted the second fastest time for a Ferrari powered car... Possibly says more about Sauber and Haas than anything else.
