F1 2016 pre-season testing
Re: F1 2016 pre-season testing
Look at the 20 lap runs on medium or soft tires like they'll use in the race this year, that will pretty much tell you everything. Lap times in the 1:30 is the time you need to finish the race with the allotted fuel, the tires are capable of much more. This 1:30 can be beaten by harder driving, DRS, and abusing the tires, or with a more aggressive and efficient engine maps. You'll notice no one drives consistently under 1:30, a second or two faster, a second or two slower, but for a race distance this is the performance for the fuel allowed.
*I'm surprised no one's tried to run the hards into the ground, or tried to see how bad the drop off is from the under tread layer.
ME4ME
79
godlameroso wrote:Look at the 20 lap runs on medium or soft tires like they'll use in the race this year, that will pretty much tell you everything. Lap times in the 1:30 is the time you need to finish the race with the allotted fuel, the tires are capable of much more. This 1:30 can be beaten by harder driving, DRS, and abusing the tires, or with a more aggressive and efficient engine maps. You'll notice no one drives consistently under 1:30, a second or two faster, a second or two slower, but for a race distance this is the performance for the fuel allowed.
What are you talking about, of the stint Vettel did, 15 laps were below 1:30.
Mercedes looking almost out of reach.
"We are dangerous" right now!
:D :D
Juzh
161
PlatinumZealot wrote:Mercedes looking almost out of reach.
:D :D
:?: Carred away a little there?
7 of those laps were close to 1:30, no one is doing consistent 1:28's on medium or hard tires(except for Mercedes) let alone 27's.
1:30 is the target lap, you can go faster than that without using excess fuel go for it, sooner or later you'll have to back off, either the heat or the tires, or fuel will make you.
:D :D
:mrgreen: I couldn't help it.
Did you get the joke though?
Rikhart
Rikhart
19
Could anyone give me some insight on what does a team gain from constant running, like mercedes with 172 laps? Aside from the obvious reliability testing, whats the point of this? I´m guessing they wont have much time to change specs, parts, etc, to run so many laps in just one day.
dans79
267
Rikhart wrote:Could anyone give me some insight on what does a team gain from constant running, like mercedes with 172 laps? Aside from the obvious reliability testing, whats the point of this? I´m guessing they wont have much time to change specs, parts, etc, to run so many laps in just one day.
a larger and more diverse data set to work from when they go to set up the car.
201 105 104 9 9 7
dren
226
They are basically doing two testing days each day. It's pretty impressive.
Honda!
GM7
Winter-Test : global conclusion (day 2).
DiogoBrand
73
I'm a little worried about McLaren: For this season not to be considered disappointing I'd expect them to at least be on par with FI, but on overall best times they have pretty much 2,5s to catch up.
I know it's just testing and we can't read too much into the stats after only two days, but with every day I start to get a little more concerned about their perspective for this year.
henra
henra
53
Care to give us some deeper insight?
ME4ME
79
TheScrutineer
TheScrutineer
Hi,
Check my blog for a roundup of Day 1 and 2 from Catalunya. Welcome you to tell me if you think its crap!
http://dmanf1.blogspot.co.uk/2016/02/ba ... and-2.html
So ted says the Ferrari had overheating issues today.
