IMO, it's quite the opposite. Increasing airflow under the floor reduces low pressure, it doesn't raise it.noel wrote:My guess, it's supposed to direct more air into the tunnel cut under the side pod and eventually towards the diffuser.fawe4 wrote:They are using it in attempt of stalling some drag at hight speed, right?
I meant the dogleg vane on the side - seen nowhere before. The barge board pieces look kinda twisted at the bottom, that and the serrated floor direct air under the car. I might have been looking at these pictures for too long, though.BreezyRacer wrote:IMO, it's quite the opposite. Increasing airflow under the floor reduces low pressure, it doesn't raise it.noel wrote:My guess, it's supposed to direct more air into the tunnel cut under the side pod and eventually towards the diffuser.fawe4 wrote:They are using it in attempt of stalling some drag at hight speed, right?
I would suggest that these strakes are an effort to continue to redirect front airflow off to the side exit of the floor, where the curved edge of the floor is, as has been done for the past 5 years or so. The best tool to do this is the ports on the sides of the tea trays, which everyone does. By exiting airfow out to the sides of the floor you lower the pressure under the floor as early as possible, therefore creating as large a low pressure area as you can under the entire floor.
As for stalling out airflow, that's an interesting idea but it would be difficult to stall out airflow without treating a lot of turbulence, which is the death of underbody down force.
That's not entirely true. You would want to have increased air flow under the floor. Remember more than anything else you are dealing with energy of the air particles.BreezyRacer wrote:IMO, it's quite the opposite. Increasing airflow under the floor reduces low pressure, it doesn't raise it.noel wrote:My guess, it's supposed to direct more air into the tunnel cut under the side pod and eventually towards the diffuser.fawe4 wrote:They are using it in attempt of stalling some drag at hight speed, right?
Perfect! Thank you!Blaze1 wrote:I don't know if this helps:variante wrote:Also, the new photos reveal more clearly that no vortex generation is directly involved with those strakes. Waiting for pics that reveal the cross section of those things to confirm it....
So, mega downforce in the middle, hopefully solving the balance issues we had post-Singapore?variante wrote:Perfect! Thank you!Blaze1 wrote:I don't know if this helps:variante wrote:Also, the new photos reveal more clearly that no vortex generation is directly involved with those strakes. Waiting for pics that reveal the cross section of those things to confirm it....
http://img1.auto-motor-und-sport.de/Nic ... 929525.jpg
So the section should look something like this:
http://i1372.photobucket.com/albums/ag3 ... ftqnwa.png ...which confirmes that the strakes work in tandem with the side diffuser.
Still, as mentioned in my first post, it is impressive that such solution was preferred over the powerful vortex shed by the lower edge of the bargeboard (no, this geometry doesn't allow for the formation of such vortex). That's the interesting thing about this W-floor.
Yep, that's about 3 complete race weekends worth of millage put on the car.noel wrote: Also, almost 500 laps without a hiccough.
Nope!PlatinumZealot wrote:No new nose?
Not surprised, it's a red herring.Morteza wrote:Nope!PlatinumZealot wrote:No new nose?
The lower surface of each strake must be a 50mm radius cylinder because the leading edge rule still applies. In that sense it is a floor with a w shaped leading edge if viewed from the top. The strake taper at the front like a cylindrical surface cutout.variante wrote:Perfect! Thank you!Blaze1 wrote:I don't know if this helps:variante wrote:Also, the new photos reveal more clearly that no vortex generation is directly involved with those strakes. Waiting for pics that reveal the cross section of those things to confirm it....
Edit: I wrote some bullshit here... I misread what you wrote, and you're right, surfaces facing the ground must be either flat or curved upwards with a maximum radius of 50mm. Even in the partially deregulated box shown here:shelly wrote:The lower surface of each strake must be a 50mm radius cylinder because the leading edge rule still applies.
Please forgive my ignorance of the nuances of the rules, as I'm just a casual fan who's trying to understand this new Mercedes development. If the "strakes" are each individual extensions of the floor how can they be exempt from the floor leading edge rule? From my layman's interpretation, it sounds like any team could then simple extend their floor forward into the "deregulated" area and then not have to comply with the leading edge rule.variante wrote:No, it doesn't: there is a "deregulated" area (shown, roughly, in the pic below) where teams use to place very thin elements like bargeboards, turning vanes and also those things we keep calling "strakes"! In other words, no radius rule applies there.shelly wrote:The lower surface of each strake must be a 50mm radius cylinder because the leading edge rule still applies.
http://i1372.photobucket.com/albums/ag3 ... epxrku.jpg
I edited my previous post.mkable1370 wrote:Please forgive my ignorance of the nuances of the rules, as I'm just a casual fan who's trying to understand this new Mercedes development. If the "strakes" are each individual extensions of the floor how can they be exempt from the floor leading edge rule? From my layman's interpretation, it sounds like any team could then simple extend their floor forward into the "deregulated" area and then not have to comply with the leading edge rule.variante wrote:No, it doesn't: there is a "deregulated" area (shown, roughly, in the pic below) where teams use to place very thin elements like bargeboards, turning vanes and also those things we keep calling "strakes"! In other words, no radius rule applies there.shelly wrote:The lower surface of each strake must be a 50mm radius cylinder because the leading edge rule still applies.
