McLaren MP4-31 Honda
tmoneyr007
tmoneyr007
Re: McLaren MP4-31 Honda
Has the Bodywork at the rear gotten a bit bigger? Would go with the Article Lucky linked.
f1rules
f1rules
594
that part under nda is a lot fatter, also the surface now ends above ther upper rear suspension part, whereas before it was well below
Yep that's the Part i was talking about, the one that looks freshly Painted.
GoranF1
GoranF1
155
Lucky
Lucky
157
ALO_Power
ALO_Power
OMG ! Rear got very fat now :shock: They seem to completely abandon the size-zero philosophy day by day. That's not very good news, in my opinion. Their initial plan was to get Mercedes by making extreme and aggressive moves like the size-zero. Now, if they abandon size-zero it looks like they just get conventional to survive. I hope I'm wrong but if you do so huge changes from Testing 1 to Testing 2 it means that you are quite lost in what direction you should take. Maybe it's better for them to start with not so aggressive packaging and let Honda evolve. But isn't it a bit too late for that? This should happen in 2015 so this year they could try pushing harder. Anyway, correct me if I'm wrong. (also super extreme packaging doesn't seem to be the way to win if we look at Mercedes so let's hope they will do well)
GoranF1 wrote: those pics not working for me....
Weird, Pictures work perfectly fine here. Did you try to open them in a new Tab?
@ALO_Power: They are not abandoning anything. They have a new engine Spec that is supposed to be slightly bigger and they have to find the right cooling Solution for that. Better safe than sorry i say. They can always shrink it back in the Future, but having to fight with an overheathing Car on the last Test is the last thing you want.
GoranF1
GoranF1
155
yes....nothing...shame i would really like to see new bodywork. :?
gloomyandy
gloomyandy
Pictures fine for me too. Does anyone have an earlier picture of that area of the bodywork for us to compare?
Lucky
Lucky
157
GoranF1 wrote: yes....nothing...shame i would really like to see new bodywork. :?
Here is the original Gallery. If that doesn't work someone is blocking AMuS for you. ^^
http://www.auto-motor-und-sport.de/bild ... 89983.html
GoranF1
GoranF1
155
it works....i think that bodywork is temporary to allow unhindered testing here...will be back to tight as soon as any reability fears are done.
aleks_ader
90
ALO_Power wrote:OMG ! Rear got very fat now :shock: They seem to completely abandon the size-zero philosophy day by day. That's not very good news, in my opinion. Their initial plan was to get Mercedes by making extreme and aggressive moves like the size-zero.
Ask last-years Ferrari team. How they made no compromised PU packaging and how well pan out for them. There we have proof how could you steer the development process. First you go big and than you go small.
That is the KEY!! Mcl Honda are one team and to help each other you sometime must go 2 steps back in order to do 3 steps further.
Better later than never.
But could they just tested package for the "hot-races". That would be also the option. But it is less likely in my opinion (all that Pu thing).
bauc
33
I'm sure that the new ''fat'' engine cover on the mp431 is just for testing only, filled under with a ton of sensors and different gimmicks. Once they feel confident enough we will see the engine cover going back to its original form/concept.
