Blackout wrote:We are trying to take the many other things into account*, you're not Webber. You're just focusing on the 'low' Merc speed trap which isnt enough.
And Merc's speed trap are often 'low'; their car generates tons of DF/drag.
The Mercs were 328kmh fast during qualy 2015 here, so with DRS, qualy engine map and low fuel. Would they somehow do 450kmh with slpitstream?
-like comparing the RS.16 with the E23 speed trap here, in qualy and winter (different wind, air temp and density) testing. The former is basically an AbuDhabi version of the latter so it should generate a similar amount of DF. Its drivers and engineers also suggest that.
And it seems the RS.16 si regularly having equal or better speedtraps. So the 2016 Renault PU might be close to the customer 2015 Merc PU. Palmer also suggests that in one of his last interviews. Autosport also suggests Palmer noticed a performance difference compared to Barcelona1...
-Some RBR speed trap irregularities compared to 2015 also imply that
There are some other hints (and official interviews) that suggest a nice progress. And no one said that progress will be enough for catching the best PU.
Now you're just being silly.
I never claimed anything along those lines I've bolded in your post.
I've even agreed that there does indeed seem to be a power increase !
All I've ever said is that many other factors need to be taken into account.
I.e. I've seen it mentioned on a few forums now, this one included, that the RBR speed was without doubt set with a nice slipstream and DRS.
We can go back and forth forever I guess, but I honestly can't be bothered.
