[KVRC] Khamsin Virtual Racecar Challenge 2016
Alonso Fan
Re: Khamsin Virtual Racecar Challenge 2016
CAEdevice wrote:In the case folder, with the same name of the folder (I rely on my memory...)
there is no file with the same name as the folder. I can't find any openable file in the folder, although it seems the analysis went quite far before failing, as there are many files regarding aerodynamic forces and meshes etc
I've installed paraview 3.9.8.1
i'll try again
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
CAEdevice
49
Yes, the first run and the mesh mapping have been done. Theoretically you could launch simplefoam by console, but singlethreaded (my advice is to wait for Julien's solution).
Could you look for the log in the models (upper) folder?
Alonso Fan
CAEdevice wrote:Yes, the first run and the mesh mapping have been done. Theoretically you could launch simplefoam by console, but singlethreaded (my advice is to wait for Julien's solution).
ah yes I've found it, although at the moment I have occfd running and it is computing. so I will post back if there is an error and i'll post the end of the log
SHR Modding
Youtube
Twitter
Discord
Alonso Fan
I got the same error with paraview version 3.98.1
so i'll post the log file
here's what I found
Create time
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file MSwindows.C at line 1314
dlopen error : "Error 126: The specified module could not be found.
--> FOAM Warning :
From function dlLibraryTable::open(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 100
could not load "libsimpleSwakFunctionObjects.so"
--> FOAM Warning :
--> FOAM Warning :
could not load "libswakFunctionObjects.so"
--> FOAM Warning :
--> FOAM Warning :
could not load "libsimpleFunctionObjects.so"
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
Reconstructing fields for mesh region0
Time = 500
Reconstructing FV fields
Reconstructing volScalarFields
nut
ptot
p
k
y
omega
yPlus
Reconstructing volVectorFields
wallShearStress
U
Reconstructing point fields
No point fields
No lagrangian fields
Reconstructing sets:
End.
any ideas?
SHR Modding
Youtube
Twitter
Discord
CAEdevice
49
Are you sure to have installed all the libraries provided with OpenFoam 2.3 for win?
etsmc
etsmc
so who has OCCFD working?
if you have it working could you list each application and version you have installed, machine spec and OS that you are running.
might help us who are struggling to get it working.
also, with machine specs, it might be an idea to include how long a test takes to run local of very stable??
I have it all installed and will give a list of versions when I can but I experience diversion in the local run and currently, a very stable has been running for about 30 hours.
Alonso Fan
CAEdevice wrote:Are you sure to have installed all the libraries provided with OpenFoam 2.3 for win?
Are all the libraries for OpenFOAM included in the main installer? Because I only used the main installer to install openfoam
SHR Modding
Youtube
Twitter
Discord
Alonso Fan
etsmc wrote:so who has OCCFD working?
Thanks loads mate
SHR Modding
Youtube
Twitter
Discord
CAEdevice
49
Well, the only release that is working is the old one (1.0, with OpenFoam 2.1), but it not inlcudes the updated cooling simulation.
At the moment I can complete a simulation with OCCFD 1.1 + OpenFoam 2.3 only using console commands, resuming the analysis after a parallelization error (but I still can't have the cooling data automaticlly processed, maybe I will find a way to view them in paraview).
Anyway: it is frustrating considering that the first race is so near, but we should consider that Julien is doing an heavy job alone and that the first race will give no points.
About the hardware: with a Win64 + i7 (three years old, 4 logical cores after switching off hyperthreading option) + 16gb dedicated to openfoam (I use it for work, so I need to save some ram) takes about 6h to complete the simulation with 6x10^6 cells (about 8h when the number of cells is around 10x10^6).
Alonso Fan
CAEdevice wrote:Well, the only release that is working is the old one (1.0, with OpenFoam 2.1), but it not inlcudes the updated cooling simulation.
How do you resumes the analysis with command lines?
SHR Modding
Youtube
Twitter
Discord
RicME85
52
Have yet to start my car. Not looking good for being ready for the test race.
I had a lot of these OCCFD issues last year so just used AWS.
CAEdevice
49
CFD support installer includes the cygwin64 console.
I launch the "simpleFoam.exe" solver into the case folder: be careful, it is a single thread solution and it requires much more time (4x on my workstation). After that you can process the results with Paraview. NOTE: you need to have completed the mesh (including mesh mapping) of the second part of the simulation. I tryed it only because I'm studying OpenFOAM (that is my primary target taking part to KVRC), but honestly it would be better to wait for an official solution.
Alonso Fan
Right. That seems long winded and I dint think my analysis completed mesh mapping. So I'll wait
SHR Modding
Youtube
Twitter
Discord
machin
162
CAEdevice wrote:Thank you! Are ready for the first race?
I think so.... my Class B "Bodykit" is ready; I haven't done any CFD testing myself, so the test race will be the first time I get to see how it performs; My plan is to enter a medium downforce configuration so that I can set a base-line: i.e. I'm not even attempting to achieve a really fast time (which would require a high-downforce set-up) I just want to understand what the balance is like, what sort of efficiency it has and most of all: how good is the cooling flow: I'm expecting this to be a real difficult part to get right and will almost certainly be way off optimised for the first run....
I must say I really like the introductory "Class B" format: Chris' base car (the "Savage LMP01" as I like to call it!) looks good, has just the right amount of standard parts, and you can knock up a reasonably good looking bodykit in a few hours; i.e. its not too late for people to enter right now....
RicME85
52
I have looked at using the intro class to get a car in the comp this year because of health and hospital getting in the way but the design confused me. I couldn't figure out what was going on with the sidepod, it has a massive step in it (I assume at the max possible floor height in that region) but it makes working with a flat floor in that area a bit awkward. Also, what is with the boxed section behind the sidepod near the rear wheel? Is this just to create a solid and the flat section at the back of the cockpit is the outlet?
