wouldn't you want to run the spark as a backup with HCCI transition/de-transition anyway? - so fulltime sparking is likely ?
the SIDI - in CI mode must have heated the charge to enable CI by using internal EGR via VVT ?
in F1 charge heating enabling HCCI must come from 'internal EGR' via raised exhaust pressure producing a small controlled under-scavenge ?
as well as the rumoured so-called HCCI, might we not contemplate PCCI aka PPCI ?
btw - 5.6 g 'braking' at Monza is about 4 g from the brakes, the rest aero and mech drag and uncorrected attitude/overshoot effects etc ?
and of course with 5.6 g deceleration the speed plummets, the DF and grip plummet, and the brake power plummets
(yes, I have suggested raising the MGU-K power)
