Hi folks,
I wondering how would we theoretically find the rear slip angle for any formula car. Finding the front slip angle is relatively easy if the cornering stiffness and the steering angle values are known. But using the some other parameters like wheel base and the front axle to CG and rear axle to CG values, is there a theoretical relation which can relate the front and the rear slip angle? Also I am assuming that the yaw velocity/rate cannot be predetermined so can't be used in a theoretical model.
I can relate the front and rear values using yaw rates but how can I assume the yaw rate in this theoretical model?
