dren
227
Re: Honda Power Unit
Postmoe wrote:IMO they have good peak power since Abu Dhabi 2015. In every single occasion they had the option to run rich they nailed top 5 laptimes, isolated or during 2-3 laps.
If that was the case I would expect better qualifying performance. I don't think the PU is competitive in peak performance yet. It certainly is a bit off the mark when in fuel-save mode relative to the rest.
Honda!
To GoranF1
Not me !!
Refer: enkidu1978 wrote:
Bence
Bence
FW17 wrote:Great find. More reasons why a company with expertise of Porsche VW should join F1.
This is NOT a VW/Porsche dyno. It's a 3rd party company called Schrick GmbH. They do development work for numerous manufacturers and/or dirtier jobs where a manufacturer's "expertise" hits a dead end, they finish/correct the development.
zac510
zac510
22
enkidu1978 wrote:
“We have a plan to challenge Mercedes in 2017,” he continued. “We are working to have a competitive car so that Fernando Alonso can win.”
I kind of have a sick feeling about this comment though... No Jenson button?
The interview is from a Spanish newspaper so he probably just mentioned Alonso, or they asked in the context of Alonso.
No good turn goes unpunished.
Postmoe
I think we can assume also that a better combustion on lean + a better energy harvesting is key in the so called qualy mode, specially during the instalation lap. That could explain why Honda underperforms in qualifying but is able to have short bursts of raw power during the races.
This is only playing with ideas, but I wonder if qualy mode could be something beyond normal full power: very low fuel consumption in instalation with maximum harvesting and then.... kaboum! Minimum weight for the performance, extreme performance in weight sensitive scenarios and radical usage of the electronics on one single lap.
I'm inclined to believe that full power during the races is relativelly conservative because there is always one more lap to go. Qualy is different, you can run until you almost fry the power unit electronics and then cruise.
Do you remember when 2 flying laps were possible for those bold and talented enough to execute them?
And in any case, looking at size zero weaknesses, specially in the sensor area, it would make sense.
Andres125sx
Also, Honda was interested on Alonso as soon as 2012 if my memory serve me well, I actually think it was some sort of demand from Honda to join McLaren. That´s the reason Alonso´s salary comes from Japan, Alonso really is Honda bet
Andres125sx
BTW, that gimbal for engines is quite interesting, but I´m not sure if the max 1G it can simulate is worth the complexity compared to normal dynos. Also, to produce 1G it needs fast rotations wich may affect some liquids (oil, coolant) on a different way than on a track where there´s no rotations at all, and Gs can be three, four or even five times higher.
For road cars that gimbal is great as it can simulate lateral accelerations of road cars (max 1G more or less), but for F1 where the PU will suffer 4-5Gs...
Dyno testing is necessary, but as a development process wich must include track testing too
NL_Fer
NL_Fer
82
Honda's qually mode seems to be powerfull but fuel thirsty. Would they be running late ignition during part throttle to keep the mgu-h harvesting enough energy, for running a full lap of mgu-k?
Craigy
84
Andres125sx wrote:BTW, that gimbal for engines is quite interesting, but I´m not sure if the max 1G it can simulate is worth the complexity compared to normal dynos. Also, to produce 1G it needs fast rotations wich may affect some liquids (oil, coolant) on a different way than on a track where there´s no rotations at all, and Gs can be three, four or even five times higher.
It'll be more than 1G max, but not sustained. (If you want sustained g, you'd need to build it in such a way as it could be rotated, like in a centrifuge).
I'd like to know if Honda use stuff like this on the F1 program, or if the engines are just so thoroughly g-proofed that they don't feel the need to.
gruntguru
gruntguru
568
I don't think the 1G is a product of inertia. It simply means the engine can be tipped over so that earth's gravity (1G) can be applied in any direction. This simulates the main problem for engines in coping with on-track forces which is the apparent inclination due to lateral Gs. The magnitude of the resultant force is of little consequence.
gruntguru
gruntguru
568
NL_Fer wrote:Honda's qually mode seems to be powerfull but fuel thirsty. Would they be running late ignition during part throttle to keep the mgu-h harvesting enough energy, for running a full lap of mgu-k?
It would be more efficient to use optimal timing and harvest from the MGUK.
Hasegawa:
We are developing all the time,” admitted Hasegawa, “and if we didn’t need to worry about the tokens we would be prepared for this upgrade.
“But at the moment we have not finalised the (token) plan yet,” he said.
Marca cited sources in saying the next upgrade is already on the test benches.
GoranF1
GoranF1
151
Honda could be on pair whit Ferrari PU if they had 40 tokens right now.
http://www.espn.co.uk/f1/story/_/id/156 ... ken-system
So basically "forget 2016, maybe 2017.... "
GoranF1
GoranF1
151
Source from Italy saying Honda plans to put compressor out of V by SPA.
