Also the engine cover seems to deflate when the car slows down. Or it's just an optical illusion?Formula Wrong wrote:Sorry that this isn't about the testing days, but I've noticed in a recently released on-board video from Vettel's Ferrari on Race-Sunday that the whole rear wing seems to move a bit down while on the straight and goes up again while breaking:
http://i.imgur.com/k3F89H8.gif
Source: Second Video here
I thought all Aero-Parts except for DRS aren't allowed to move like that? I am noticing this for the first time (never noticed it like this on another car before) so it does look kind of weird to me.
Now that you're saying it, i see that slight movement you mean. However, that might actually be only an illusion caused by the camera being shaken a bit by the deceleration. At least I can't imagine any advantage a "deflating" engine cover would give; while a rear wing that bends would cause less drag on a straight.atlantis wrote:Also the engine cover seems to deflate when the car slows down. Or it's just an optical illusion?Formula Wrong wrote:Sorry that this isn't about the testing days, but I've noticed in a recently released on-board video from Vettel's Ferrari on Race-Sunday that the whole rear wing seems to move a bit down while on the straight and goes up again while breaking:
It looks like the rear wing is flexing backwards on the support pylon, reducing AOA. Could this be what's causing the appearance (real or imagined) that the engine cover is also deforming? The monkey seat moves an incredible amount.Formula Wrong wrote:Now that you're saying it, i see that slight movement you mean. However, that might actually be only an illusion caused by the camera being shaken a bit by the deceleration. At least I can't imagine any advantage a "deflating" engine cover would give; while a rear wing that bends would cause less drag on a straight.atlantis wrote:Also the engine cover seems to deflate when the car slows down. Or it's just an optical illusion?Formula Wrong wrote:Sorry that this isn't about the testing days, but I've noticed in a recently released on-board video from Vettel's Ferrari on Race-Sunday that the whole rear wing seems to move a bit down while on the straight and goes up again while breaking:
They are already doing that for years. I believe it was first reported somewhere in 2004(?)Formula Wrong wrote:Sorry that this isn't about the testing days, but I've noticed in a recently released on-board video from Vettel's Ferrari on Race-Sunday that the whole rear wing seems to move a bit down while on the straight and goes up again while breaking:
You are correct, I've found an article and even a topic in this forum about this issue; both from 2006wesley123 wrote:They are already doing that for years. I believe it was first reported somewhere in 2004(?)Formula Wrong wrote:Sorry that this isn't about the testing days, but I've noticed in a recently released on-board video from Vettel's Ferrari on Race-Sunday that the whole rear wing seems to move a bit down while on the straight and goes up again while breaking:
But doesn't this have the same result? Whether it's only the profile that bends or the entire structure, the angle of the wing still changes, doesn't it?BlackSwan wrote: Also in this case I can't see flexible profile in the video, but only the entire rear wing structure that bends over the aerodynamic load and probably there is not a regulation that does not allow this bending.
Sorry for the long post and if I am wrong sorry two times!
That is a significant change in angle, if that really is related to the heat from the exhaust expanding the support pylon I think it won't be long before this is a big talking point in F1.bhall II wrote:Anyone know if they still run the center pylon through the exhaust pipe?
http://i.imgur.com/vj5uSTl.jpg
It would seem the matter is decidedly more complicated if they do. (It might also suggest that enabling the wing to flex by way of exhaust heat is what allows it to pass a flex test that's administered in ambient temperatures.)
Formula Wrong wrote:http://i.imgur.com/k3F89H8.gif
That's absolutely genius if that is why they did it.bhall II wrote:Anyone know if they still run the center pylon through the exhaust pipe?
It would definitly be. However, there don't seem to be any detailed pictures of Ferrari's rear/exhaust from Spanish GP and on different perspectives from the race-feed you can only see black inside the main exhaust. Does anyone have good connections to a motorsport-photograph who could try to catch a good pic at Monaco?ecapox wrote:That's absolutely genius if that is why they did it.bhall II wrote:Anyone know if they still run the center pylon through the exhaust pipe?
