If people here think what Britney did was perfectly acceptable, how would you appreciate the whole grid taking this approach?
If the 'corner dive-bomb' became standard the only overtakes in F1 would be DRS overtakes as the leading driver would always be able easily defend in the braking zone. Not to mention driver trust would be eroded, a following driver has every right to expect the leading driver is braking to take the corner on the racing line unless they out brake themselves in which case the following driver has likely gained an advantage.
If you support Britney's boneheaded move then you in effect support making F1 even more dull as a better driver behind or a better car more able to take the outside line through a corner will always be nullified by the leading driver relaxing on the brake pedal. The German GP was boring enough without every driver using the corner dive-bomb if everyone is doing it'll I'll find something else to do on Sunday afternoons.
