Mercedes AMG F1 W07
Edax
Edax
47
Re: Mercedes AMG F1 W07
hollus wrote:The article cites increased surface as an advantage. The increase in surface would appear to be rather minimal and one would think that most cooling is via flow through the holes anyways, and that exchange surface is being diminished by the scalloped edge.
What other advantages could this shape bring?
Just a guess. Would this not increase the view factor and increase the radiative heat transfer to the drum? That could serve both brake cooling as tyre heating.
ClarkBT11 wrote:Have they made the heave unit unit smaller(lighter) and lowered the unit lower down?
Seems so. Could be just typical weight cutting.
misterbeam
misterbeam
poolboy67 wrote:
and yet the car doesn't have any visible tricks to it, like an f-duct or whatever we've had in the past. in fact, it looks simple to me. the way other teams are reporting their HP gains on new engines, merc should be around 1200bhp by now! that's about 450bhp above of what the regulations were supposed to be designed for, an engine of around 750bhp. fuel flow limits and all that.
i think merc have found that loophole or whatever. and f1 is dirty. the term "motorsport" doesn't apply to f1.
I don't think that Mercedes has reached 1200 BHP yet, probably around 950-980 BHP in quali, that's like 790 - 820 BHP from the V6 Turbo alone, which is already too much.
Juzh
161
1200 :lol: :lol: #-o #-o =D> =D>
poolboy67
sarcasm. of f**** course their PU doesn't make 1200.
No PU talk/jibber jabber in the car thread please.
Juzh
161
Sorry, didn't spot it right away.
EDIT
Drica
If you are referring to the R-cascade bit, the "new" wing seems to have some sort of spacer which is, i believe, removable and only for transportation purposes
My bad. Should have paid more attention ](*,)
Juzh
161
Spa and monza spec? Unlikely they'll use hamilton's version at this gp imo.
Jolle
Jolle
133
Could be part of the "overtaking the field" job that Hamilton has to do. Bit more top speed at the end of the straights makes it easier, even if his ultimate laptime is a few tenths slower. Plus he doesn't have to qualify (and over a race, a bit less drag might be faster)
djones
djones
Did anybody see what wing Hamilton used in FP3?
Unc1eM0nty
djones wrote:Did anybody see what wing Hamilton used in FP3?
It was the Rosberg wing pictured above
