The maximum pressure for the cooling system is 3.75 bar. The pressure is created by the expansion of the water and gas within the closed volume of the cooling system. In a racing application the expansion tank can also be pre-pressurized with compressed air.ringo wrote:You have to develop that pressure somewhere. Something has to generate that 9 bar of pressure if you insist that's the suction pressure of the pump. It could be from heating the water, but that is not likely at all from 1 bar to 9 solely from heating. It would not be desirable.
But i don't think there is a need for such high pressure as the physical properties of the water wont change much.
Also you are looking at heavier construction with containing 10 bar pressure as opposed to 3 bars.
7.5 Coolant header tanks :
Any header tank used on the car with a water based coolant must be fitted with an FIA approved pressure relief valve which is set to a maximum of 3.75 bar gauge pressure, details of the relief valve may be found in the Appendix to the Technical Regulations. If the car is not fitted with a header tank, an alternative position must be approved by the FIA.
Agreed. I don't actually believe the systems run at 10 bar or that the pump inlet is at 9 bar. Just saying that a pressurised water system does not use the pump to generate the pressure.ringo wrote:You have to develop that pressure somewhere. Something has to generate that 9 bar of pressure if you insist that's the suction pressure of the pump. It could be from heating the water, but that is not likely at all from 1 bar to 9 solely from heating. It would not be desirable.
So just normal pressures then. I think that is the pressure on my radiator cap.Edis wrote:The maximum pressure for the cooling system is 3.75 bar. The pressure is created by the expansion of the water and gas within the closed volume of the cooling system. In a racing application the expansion tank can also be pre-pressurized with compressed air.ringo wrote:You have to develop that pressure somewhere. Something has to generate that 9 bar of pressure if you insist that's the suction pressure of the pump. It could be from heating the water, but that is not likely at all from 1 bar to 9 solely from heating. It would not be desirable.
https://www.youtube.com/watch?v=jSG37vjU3S4
Yes, but there can be side effects.hurril wrote:Why not? There are benefits to running a hotter cooling medium.tok-tokkie wrote:A radiator that can handle >10 bar wold be some piece of work. And for what thermal advantage? At 10 bar (gauge) the temp of boiling water is 184°C. Just what you don't want for a cooling device.
In a normal engine, the relief valve on the expansion tank typically open around 1.5 bar.PlatinumZealot wrote:So just normal pressures then. I think that is the pressure on my radiator cap.Edis wrote:The maximum pressure for the cooling system is 3.75 bar. The pressure is created by the expansion of the water and gas within the closed volume of the cooling system. In a racing application the expansion tank can also be pre-pressurized with compressed air.ringo wrote:You have to develop that pressure somewhere. Something has to generate that 9 bar of pressure if you insist that's the suction pressure of the pump. It could be from heating the water, but that is not likely at all from 1 bar to 9 solely from heating. It would not be desirable.
The problem is that you start reach annealing temperatures for aluminum alloys from about 150-160 degC, although there are aluminum alloys that can withstand 200-250 degC too, so this can be solved with material selection. Running such high temperatures will cause other problems though, like problems with lubrication of the cylinder, even higher piston temperatures, knock and loss of volumetric efficiency.godlameroso wrote:We know you can coat parts to your heart's content, but the main block still has to be made from aluminum. The problem with aluminum is the low fatigue point. 150-160c is pushing it as far as bare aluminum is concerned.
I was talking to Lake Speed about this in NASCAR, here is an article where he discusses itringo wrote:So you would have to have an oil engineered to give the tight lubrication and viscosity characteristics at higher temps to carry all that heat away.
