godlameroso wrote:Interesting, perhaps they have all those slotted surfaces to prevent separation because the chassis rolls so much. Maybe the aero is designed with the chassis roll in mind. In that it's more effective when the chassis is pitched left or right.
That's quite interesting. If you designed your car to have high downforce under body roll conditions you could eliminate some drag on straights (hypothetical).
This would be VS. the philosophy of having a very flat car through turns to maximize downforce performance VIA stable floor conditions.
Slightly counterintuitive but very interesting.
Not saying that's happening but I can't imagine a team TD not investigating the value of the philosophy in simulation.
