Thank you very much.hollus wrote:Yes, look on formula1.com
Watching Hamilton's qualifying lap it seems the chassis rolls regardless of the state of weight transfer. Even the slightest movement causes roll. Really makes you wonder.godlameroso wrote:Interesting, perhaps they have all those slotted surfaces to prevent separation because the chassis rolls so much. Maybe the aero is designed with the chassis roll in mind. In that it's more effective when the chassis is pitched left or right.
When he parked the car the smoke went straight up like you said.Paul wrote:It is hot smoke though, which tends to go upwards anyway, so not an exact evidence of usual flows in that area..
I did not hear anything lolhurril wrote:Thank you very much.hollus wrote:Yes, look on formula1.com
Well, you can clearly hear it throwing a rod or something very mechanical. There's a boop and change in turbo sound as well so something went out the exhaust. Perhaps a valve hitting a piston and then leaving through the turbine. The engine did provide a little power, responding to gas.
The Holy suspension!
