That is fine, there might be more to come. It looks like you are using the older release. The new one tells you that you are working with a binary stl file. But wait until tomorrow, there will be a new release (probably).
And please use the Challenge forum. It is for software issues. I do not want to abuse F1technical as a support forum for my software. Also your issue is documented and solved over there. So using it would have saved you valuable time.
