diffuser wrote:It sounds like when they increase downforce on the front wing they hit a point where they're diverting too much air from the rear. This results in loosing the seal of the floor and the dramatic oversteer.
That would also explain y sasha said they wanted to lower the rear but can't get the rear suspension to work lower to the ground. If the rear/rake is lower to the ground, the seal is easier to maintain. Although,lowering the rake doest resolve the problem...just works around it. I mean you loose all the advantages of the rake.
The new front wing, introduced at singapour, has the first few flaps moving more air to the middle of the car. I presume that's what they were expecting to maintain the seal.
Be interesting to know if it helped at all? Did they impove it and just not enough or what?
Makes sense, probably a big reason why they started adding more elements on the upper flap, so as to try to not disturb the air that flows to the barge boards and floor. Mercedes has little strakes on their upper flap, barge boards, and rear wing, and Ferrari has serrated edges on their front wing. Red-Bull and McLaren have similar front wing philosophy but the interpretation is different. The Red-Bull inner wing flaps starts working the air sooner so they tried to design a front wing that has maximum downforce while disturbing the rear flow as little as possible. They would just balance front downforce with the rear end. The McLaren wing inner section shapes the air less aggressively to start, so they depend more on flap angle adjustment, but can't balance the rear end as finely as the Red Bull, because the flap angle adjustments disturb the rear flow.
Like I've said before, it doesn't look like they bothered to do too many changes to the rear wing(save the end plates). It's almost like they were trying to use a known constant and try new things around it. Almost like a validation study, and they were mainly testing things that could carry over to next year. I think McLaren could have solved the chassis issue but it would have wasted resources for next year. With the state of the current power unit and the big step forward planned for next year, it's not inconceivable to think that the chassis strategy has been focused on next year. Trying out new things that can work next year and if they bring an aero benefit this year to leave them on the car.
It's not an ideal way to update a car, because it's going to have the same flaws all season, on the other hand, the things that make a chassis fast this year, may not work next year. Without serious re-development and fine tuning, what worked this year may be a waste of time next year. It may also be a waste of resources when you consider there will be numerous areas that can clearly give you massive gains for a lower investment, especially if you start to focus on them early.
Seeing is believing however
http://www.f1fanatic.co.uk/2016/03/07/c ... ery-angle/
Compare the Red Bull and McLaren front wing, look at the bottom inner flaps tell me which one starts to work the air sooner.
