Looks to me it's more a retro look thing then a revolutionary design feature.theriusDR3 wrote:https://pbs.twimg.com/media/CvwIwxdVIAAS82E.jpg:large
IndyCar Series 2018 season will ditch the airbox intake and replaced by Champ Car-style engine cover. F1 looks to switch from airbox intake to Champ Car-style engine cover in the future because of revolutionary car design.
I don't think the esthetics would be an issueJolle wrote:Looks to me it's more a retro look thing then a revolutionary design feature.theriusDR3 wrote:https://pbs.twimg.com/media/CvwIwxdVIAAS82E.jpg:large
In both series the general shape of the airbox or the lack of it is mandated in the rules, but looking at f1 how the teams like to replace some of the sidepod volume with a bigger airbox, I won't see it happen.
It's an estetic thing as well, for the last 30-odd years F1 had airboxes above the drivers head, the marketing people think it's one of the key aspects what makes a f1 car a f1 car.
In the early 2000's the covers were acually getting smaller but they gave them a minimum surface for sponsors indeed.Formula Wrong wrote:I don't think the esthetics would be an issueJolle wrote:Looks to me it's more a retro look thing then a revolutionary design feature.theriusDR3 wrote:https://pbs.twimg.com/media/CvwIwxdVIAAS82E.jpg:large
http://www.wallpaperup.com/uploads/wall ... 5b66b0.jpg
But as you have stated; the rules are very tight; unless they actively change the rules we probably won't see such engine-covers. Furthermore, it would mean less room for sponsors
Nope, they won'tFormula Wrong wrote: I don't think the esthetics would be an issue
With the correct sizing the scoop becomes more or less neutral (the air gets sucked in by the speed of the car) or even positive. Plus any obstruction is a loss. Because there is a rollhoop mandatory in that place, having air sucked trough it makes lots of sense.strad wrote:With the turbo do they really get as much benefit from the ram air effect?
If so would it not be aerodynamically better to get rid of the scoop part and draw air from a better place?
Plus some of the teams are using that area to feed other coolers.Jolle wrote:With the correct sizing the scoop becomes more or less neutral (the air gets sucked in by the speed of the car) or even positive. Plus any obstruction is a loss. Because there is a rollhoop mandatory in that place, having air sucked trough it makes lots of sense.strad wrote:With the turbo do they really get as much benefit from the ram air effect?
TruePlus some of the teams are using that area to feed other coolers.
It's not just the ram air effect, it's also an aerodynamically efficient way of getting air into the engine, especially since the turbo placement rules probably means that any configuration you pick for your airbox will more than likely require a close to 90 degree bend in the flow.strad wrote:With the turbo do they really get as much benefit from the ram air effect?
